Question about Nakajima AE-740 Typewriter
I just found a Hermes 3000 typewriter today. I fixed an old corona years ago that had the same problem. Everything works except when you type a key it does not continue to move along so each letter piles on top of the last. I have begun gently taking it apart recalling what I did with the other typewriter. The problem is similiar there is a small spring supported wheel that attaches by what in this model is like fishing line to a small hook (on the other model it was string). I am wondering how to reattach it i have tried both directions and cannot seem to get the appropriate tension. I am also unsure if this is the only problem with that is causing the lack of movement. Thanks!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 130 Answers
You have to wind up the spring drum. the round thing, be sure to wind it the correct way. in the pull of the direction.
Wind up about five time then attach the cord.
Posted on Dec 03, 2017
SOURCE: Nakajima AE-830
The typewriter is set in P.S. mode instead of 10 or 12. This switch is in lower left corner of keyboard.
Posted on Oct 03, 2007
JUSTOLDJIM
  • 475 Answers
SOURCE: Symbols & number OVER Number Keys
The typewriter is in the keyboard ll position, hold down the code key while touching the KBll key (5)
Posted on Jun 04, 2008
  • 3594 Answers
SOURCE: AE-710 Letter Keys Do Not Work
Check the pitch selector switch if it is in PS this will cause this problem.
DickyO
Posted on Dec 30, 2008
  • 75 Answers
SOURCE: I am trying to type
there is a slide switch on the L.H. side of the key board that reads 10,12,15, PS
the switch needs to match the print wheel stile you have in your typewriter. most typ's have 10 or 12.
PS stands for proportional spacing a takes a spicule print wheel
Posted on Jan 24, 2009
squipps
  • 204 Answers
SOURCE: return arm on smith-corona silent typewriter does not advance
The linespace selector lever is probably at zero 0
try moving it to 1 1 1/2 or 2. There is also a detent lever that releases the ratchet of the roller. You should feel a bumping when you move the roller wheel.
Posted on Dec 19, 2009
My L key is stuck DOWN! How do i fix that ?
WD40 fixes everything. Turn it upside down and follow the L - Key from the top. Then follow it to the striker key. I can't remember if they have individual return springs. Been a long time :>)
Dec 28, 2015 | Smith Corona Office Equipment & Supplies
Margin release hermes 3000
It's been a while since I've seen a Hermes but i believe the margin release key looks like >//<
DickyO
Oct 06, 2014 | Office Equipment & Supplies
Where can i get a manual for my smith-corona typewriter?
Can you give us any help in identifying the machine? Is it manual or electric, for example?
There's a downloadable and printable manual for the Smith-Corona Standard Portable here.
Bear in mind that if this is an old typewriter then there is a very good chance that no one has bothered to rewrite the manual since the invention of the internet. In such cases the best you can expect is a scan of an old paper manual.
Mar 29, 2012 | Smith Corona Office Equipment & Supplies
I have a smith corona sd680 work processor typewriter. When I type the letter don't come out clear and I have to type over and over in order to read the letters. This is an old typewriter in the office...
This problem is usually caused by an old ribbon theey do dry out when left in tthe typewriter a long time, also if the paper is really hard or has a slick surface the ink from the ribbon will not stick to the paper.
Dec 14, 2010 | Smith Corona Office Equipment & Supplies
Smith corona SL480 instruction manual. I just need a manual so I know how to use the features built into the typewriter
How to Use a Smith Corona Typewriter A Smith Corona typewriter can be either a manual or electric model. Whichever model you have, the typewriter works in basically the same way. If you are familiar with a computer keyboard, you can type on a typewriter as the keys are laid out exactly the same. Unlike a computer, typing mistakes are harder to correct and, unless you use carbon paper, you will only have one copy of any document you type.
Aug 03, 2010 | Smith Corona Office Equipment & Supplies
Hermes 3000 tab stuck in middle.
After you press the margin release key, space to the desired R. margin location, press the R. MAR key.
DickyO
Jul 10, 2010 | Office Equipment & Supplies
Typewriter keys malfunctionE
Al these keys are at the right side of the keyboard andwould seem to indicate a broken track on the keyboard printed circuit board. It is repairable with a soldering iron and great care.
Apr 13, 2010 | Smith Corona Wordsmith 200 Typewriter
I have an old Hermes 3000. I was in the middle of typing away and the machine was working perfectly. Then all of sudden the carriage will no long stop. It just slides directly to the right margin and stops...
It might be that you tab key is engaged which would do this. also try gently moving the carriage to a point, pressing the space bar and then releasing the carriage. It might be the escapement..
Hope this works!
Dec 09, 2009 | Office Equipment & Supplies
File? 12345678
Is the typewriter a Smith Corona SD 250? If so, you have entered the "memory" mode by mistake. Over on the left side of the typewriter is a switch marked "MEM", "LINE", and "TYPE". Move the switch down to "LINE" or "TYPE" to resume normal typing. DO NOT PRESS ANY NUMBER BUTTONS ON "MEM" MODE! Does this information fix your problem?
I just got this typewriter a few days ago so I don't know everything about it yet... But I believe that this is one way to fix your problem.
Best of luck to you!
Feb 23, 2009 | Smith Corona Wordsmith 200 Typewriter
Smith Corona XD 6500
You might check the outlet to make sure there is 120V. Otherwise there is a good chance the power supply has burned out. Also the cover has to be down, and there has to be a ribbon mounted properly for this machine to work.
Aug 27, 2008 | Smith Corona Wordsmith 100 Typewriter
Nakajima AE-740 Typewriter Logo
95 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
