My coupler went out I removed the motor and pump and replaced the coupler reinstalled the motor then the pump spins and agitates fine now...however when the spin cycle stops the tub lurches violently what could be the problem ?
  • Washing Mach... Master
  • 2,005 Answers
The tub clutch / brake assembly located on the tub bottom
Posted on Jul 22, 2010
Machine is not agitating correctly. It is moving with almost zero force. When the I was checking to see if it would spin, when the spin got fast I began to hear clicking noise.
HI. the internal components that make up the agitator should be inspected for damage.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction. Another issue that might cause this disruption is the Motor coupler.
Washers with a direct drive motor have a motor coupler instead of a belt. The motor coupler consists of three plastic disks (or tri-stars) with interlocking tabs. Those tabs can wear and break which results in slippage. The slippage causes little or no power to be transferred to the transmission. A worn motor coupling can result in weak or no movement of the agitator and spin basket. Inspecting the motor couplers requires removing the motor, which is fairly easy to do.
Remove the cabinet. Locate the motor. The pump is mounted to one side of the motor. You do not have to remove the hoses from the pump unless they prevent you from moving the pump out of your way. If you must remove the hoses, label where they connect first. To disconnect the hoses, pinch the wire clamps with pliers (or loosen the screw) and slide the clamp farther up the hose. Slide the hose off of the pump port.
There are two clips that secure the pump housing to the motor. Use a screwdriver to pry up the clips and remove the cover. Next, slide off the pump to reveal the motor. Disconnect the wiring harness from the motor, do not pull on the wires themselves. The motor typically is secured with retaining clips and bolts. Remove the bolts and use a screwdriver to pry up the clips (if present). Remove the motor.
Mounted on the shaft of the back of the motor you will find the motor coupler. Separate the three disks and inspect them for damage. If you find cracks or excessive wear, replace the coupler.
**(((If the motor couple is in good condition, replace the agitator components and clutch assembly as well.)))
Jan 07, 2010 | GE WSKS2060WWH Top Load Washer
Agitator on a Inglis Niagara washer
Dec 31, 2009 | Washing Machines
Won't agitate and makes loud noise during this time, it spins
Dec 04, 2009 | GE Washing Machines
Performa Washer model PAVT454EWW does not agitate, loud noise comes from near shaft under drum. Spins fine, belt moves fine. Is there a motor (''agitator motor'') other than the main motor that is at front...
Oct 08, 2009 | Maytag Washing Machines
Aggatator does not turn fast enough during wash cycle or spin fast enough during spin cycle
Oct 04, 2009 | Speed Queen Washing Machines
Will not agitate , or spin
Sep 15, 2009 | Maytag Washing Machines
My washer spins fine but will not agitate.
Sep 14, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Will not agitate but spins
Sep 10, 2009 | Amana LWA90A
My Kenmore Series 70 won't agitate or spin. Motor is running.
It sounds like your drive coupler is bad. If you replaced the dogs in the agitator, you can fix this. Unplug the machine. From the bottom you can access the motor. You will have to remove the water pump by prying off the two straps with a screwdriver. They may have a safety screw holding them on, if so remove it first. You may need to remove the hoses on the pump. Pull the pump off. Then you can remove the motor safety screws and straps (2) like the pump straps. You can pull the motor off and the 3 pice coupler is there. One rubber and two (usually) plastic drive parts. If they are bad (you can tell, broken plastic or rubber shot) replace with new kit. A kit is avalible online for about $14.00.
Aug 05, 2009 | Kenmore 22422 Top Load Washer
Won'i\t spin or agitate. was working fine-went
Hi..
if agitator movement is weak or moves in only one direction check the following:
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt(belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
If drum does not spin check this:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the drive belt (belt drive only)
  • Test the motor
Good luck !!!
Regards
PCmania
Jul 11, 2009 | KitchenAid Washing Machines
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
