Question about Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
Need to replace the starter cord. How do you pretension the springs/
Starter recoil spring reload, How?
If the spring is unwound.
Recoil Spring Rewind
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If the starter cord needs a pretension, this works quite well.
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 26, 2010 | Homelite Garden
Rewind pully spring
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Oct 06, 2009 | Poulan Pro Chain Saw 46cc 20"
Craftsman gas chainsaw 18'' model 358 pull start repair
Lou
Sep 20, 2009 | Garden
Rob poulan leaf blower how to rewind pull string
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
Both methods require about 2 turns of pretension to rewind the cord when pulled. HTH
Lou
Sep 05, 2009 | Poulan Garden
Pioneer chain saw mo# p411 starter pull rope does not retract spring came off post and was repositioned how do I ''pretension''
The spool on my Pioneer FarmSaw says 2½ turns clockwise. Remove pull handle, place cord in notch, now it be pretensioned. Feed cord back through cover and reistall handle. Lou
Jul 30, 2009 | Garden
I have a poulan p3315 14" chainsaw. The the recoil won't work. I took the assembly apart and I can't get the recoil spring back in. I would like to buy a new assembly. Do you know where I can buy one?
Poulan.com Look your saw over carefully and maybe you'll find a model number that matches one of these.
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
Lou
Jul 18, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
My recoil inside the pullstart
Jun 08, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Starter Pulley Jammed
A new spring can be found here:
Poulan.com
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool when inserted. It will require about 2 turns of pretension to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and wind the withdrawn cord onto the spool. GL
Lou
May 28, 2009 | Poulan Garden
Broken recoil spring
Lou
Mar 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 18 Inch replace starter spring?
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
Lou
Oct 09, 2008 | Poulan 1630 16" Chain Saw
Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766 Logo
27 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
