Question about GE Dishwashers
Hi, I have a ge dishwasher, model number VSD2304J00WW and it does not run properly. When I turn it on, it will hum and then start to make a clicking noise. Then there will be a bad smell, and a little smoke. Also the water does not drain. I've had water in the bottom of it for a few weeks now. The cycle never finishes either.
the dr
  • 447 Answers
SOURCE: Diswasher
You will have to test the solonoid electrically now its probably getting juice and the solonoid may have failed. You can get just the solonoid ot the entire pump assy for a little more.
Posted on Oct 03, 2007
SOURCE: dishwasher not always draining
If the dishwasher drains through the vent pipe on your sink it may be clogged. I had that problem as well. Unscrew the vent cap and look for junk. In my case of all things it was dog hair!!
Posted on Nov 24, 2007
  • 126 Answers
SOURCE: dishwasher not draining
if its new call your dealer its a warranty call
Posted on Dec 22, 2007
SOURCE: GE Dishwasher is not draining water
GE Prifile dishwashers have a valve called a "Piston" and an "O" -Ring under the screen that become degraded over time. The part is around $10 and it takes about an hour to do the repair. You can do this yourself if you are handy and have some simple tools. You can go to the GE website and get a free owners manual.
Posted on Aug 01, 2008
mreid542
  • 166 Answers
SOURCE: GE Nautilus Dishwasher
if the dishwasher has not been used for a few weeks, the water in the sump that goes into the pump will evaporate causing the pump to freeze up. usually you can turn the fins inside the motor to free it up. make sure the dishwasher is not on when you do this.
Posted on Nov 20, 2008
Motor hums but won't start
chances are the pump is blocked as well and unable to spin
Nov 03, 2013 | Dishwashers
The blower fan on my AC/Heater isn't working properly.
check the capacitor on the moter or just replace 12.00 bucks. if it doesnt work you need new moter.
Oct 23, 2012 | General Electric GENERAL ELECTRIC...
GE Dishwasher motor hums but doesn't engage.
These motors will stick sometimes during periods of not being used. With the power turned off to the the dishwasher, remove the front lower grille. There are usuallly 2 screws on each side of the panel. Looking under the D/W your will see the motor and pump assembly. If you feel around you should be able to feel the motor's cooling fan. Simply rock the fan back and forth and the motor/pump should become unstuck.
Jun 21, 2010 | GE 24 in. GSD2000Z Built-in Dishwasher
Problem with candy dishwasher model CSF 456M.
hi it may need a new inlet valve,can you hear a humming sound when its due to fill.or is it doing nothing.if its not humming change the valve,also these dishwashers are well known for overheating and sticking on cycle.
Jun 01, 2010 | Dishwashers
GE Profile dishwasher makes a humming noise
I had the same problem. The issue is due to the top rack water inlet not properly seating against the water line in the rear of the washer. I fixed it by placing heavier items (bowls, glass cups) on the rear of the rack and lighter items (plastic cups) near the front of the rack. As long as I arrange items on the top rack in this way the washer runs silently.
Oct 08, 2009 | GE GSD3800G - Multiple Color Built-in...
GE diswasher hums but will not start cycle and starts to smell ho
Hi, Have your freind check and see if the water supply line under the sink has been turned on. The hum you are hearing could be the inlet valve. Please let me know if this has been helpfull or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | General Electric CDW9380N Built-in...
Refrigerator is not cooling properly/fan is not running
HI,
The click and hum your hearing is most likely the compressor trying to start. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
anu further question don't hesitate to contact me.
thanks,
Mar 23, 2009 | Refrigerators
I have a GE Potscrubber dishwasher that only hums, won't run
I have a portable that had the same problem. I called a repairman and he turned a fan blade on the motor. Mine is located on the right side about 12" in. It gets hung up when it is run often enough. If your problem is the same is mine all you have to do is turn the blade and it works like a charm. Hope this helps.
Feb 18, 2009 | GE 24 in. GSD2000Z Built-in Dishwasher
Ge dishwasher not drying
1 make sure heated dry is on.
2 run your cycle and when it says drying open the dishwasher. see if it has steam coming out.
3 give me your whole model number.
4. if heater is not turning on then you may have one of three issues.
1. Bad door switch
2. Wire off element or bad thermistat
3. No power going through the control. to the heating circuit.
Jan 07, 2009 | GE ADW1100N Built-in Dishwasher
Open Questions:
Dishwashers Logo
213 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
