Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Flashing time on a Hunter Programmable Thermostate #44665
We have a Hunter Programmable Thermostat model 44665 in our church. It worked well through the heat season and seemed to be working last month - it was certainly keeping the room cool. Now, however, we are seeing the time flashing on the display and an asterisk above the am/pm notation. We changed the batteries, updated the programming, and I've pressed the Ret/Clear button. The unit does produce cool air, but still the time keeps flashing and shows the asterisk. Since our other two matching thermostats don't flash and don't have the asterisk, that seems to indicate that something isn't set right.
  • Teresa W Jul 22, 2010
    I discovered what the flashing time problem was: Someone had pushed the Day/Time (date/time set) button. Since the time was still accurate, I didn't think to check it. A simple push on the Day/Time button fixed it.
    I'm still curious about the asterisk above the AM/PM display.
    Sergeant:
    Champion:
  • 277 Answers
Teresa
have a cental air guy in for a check up on your units. they may need servicing
Posted on Jul 22, 2010
SOURCE:
My Hunter Programmable Thermostate #44110. I set it for regular clock time. But in the middle of the day and night it goes to military time. When I hadn't added military time. Is it time to buy a new one. I've had it for 8 years.
Apr 15, 2015 | Hunter Fan Company 7-day programmable...
Hunter 44665
You can get the manual at: http://www.manualslib.com/manual/257219/Hunter-44665.html
Normally these thermostats read remote temperatures but do not use them for control. The external remote sensor is normally put outside in our area yeilding an inside out side thermometer.
Nov 22, 2013 | Hunter Fan Company 5/1/1 Programmable...
Programming the remote sensor to the 44665 hunter thermostat
Just fixed mine;
Note the sensor channel on face of remote
(ref: http://www.manualslib.com/manual/257219/Hunter-44665.html)
Mine was set on Ch15, well the thermostat only monitors 14 channels had to flick down dip switch #1 to set Ch7.
Then on the base unit thermostat, see page 5 of a similar unit for 44668/44665 manual (below) then wait about 10 minutes for things to sync up, and press remote button to check sensor temp.
Note the button order for Remote Sensor Programming at base thermostat:
http://www.hunterfan.com/SupportDocuments/OwnersManuals/44008-01Thermostat44668-44660WebR02102010.pdf
Feb 05, 2012 | Hunter Fan Company 5/1/1 Programmable...
I need to program the 44665 thermostat
enter "hunter 44665" in your internet search box, it should give you several sourced of the manual, both free and for a charge.
Good luck,
Gilshultz
Dec 03, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44260 Thermostat Problem
make sure you have the jumper in place
if you dont have a secondary heat source red should be on r with a jumper to rh
Oct 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
My hunter thermostate keeps flashing a 4 and wont turn on !
hunter thermostats are not the highest quality. on the back of the thermostat there should be a not well identified reset button. You can locate and push this to attempt to fix the problem. Or purchase a new (i would suggest Robertshaw or braeburn) thermostat and install.
Dec 14, 2008 | Hunter Fan Company 5/1/1 Programmable...
Progrmmable Thermostate
Check to make sure you have pm or am set correctly. Or reset everything. ??? ;)
Dec 13, 2008 | Hunter Fan Company 5/1/1 Programmable...
Programmable Hunter Thermostat
hi
this site as the owners manual you can download in pdf . if this helps you out .
Programmable thermostats at discount prices at hunter-thermostats.com.
riz.
Nov 14, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
1,289 people viewed this question
Top Hunter Dryers Experts
Joe Paxton
Level 1 Expert
Paul Bade
Craig Butler
Craig Butler
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
