Question about Microsoft HP Pavilion DV6276US Notebook PC
The left button below my mouse pad is not working on hp pavilion
The left button below my mouse pad is not working properly. how can i fix it
    Sergeant:
    Champion:
  • 277 Answers
Blkcooper
Give Hp a shout.. and they will send you one. when you get it, come back onlie and I do a step X Step procedure for you
Posted on Jul 22, 2010
Samsung laptop mouse left button
-If me I'll buy a new mouse.
Good luck
Mai
Jun 16, 2017 | Computers & Internet
My mouse is frozen on my hp dm4 and the orange light in the left hand corner is not on, nor will it turn on when double tapped
First thought is look at the top of the touch pad, there is a button. Push this button once and see if the mouse works. HP put this button on to deactivate the mouse if needed.
If this does not work, plug in an external mouse and see if it works, if not do a hard boot on the computer and try the mouse again.
Jul 20, 2011 | HP Pavilion dv6000z Notebook
My daughter spilt a bit of cranberry juice on my touch pad. I have a hp. The mouse is working but the left button is a no go and the right one only registers sometimes. What can i do to fix this and make...
Hi, dry it using hair blower to make sure the moist go. To fix your mouse left button, try to unscrew the mouse casing and see to it that by clicking it really contacting with the switch button. Wear and tear also damage the solder of the switch button. it will be fixed by re-soldering the mouse switch if loosen.
Jun 21, 2011 | HP Computers & Internet
Hp pavilion dv4 left buttom not work
left click is membran switch it was fix in motherboard
need to replace it .
for tapping control you can set as per your comfort from
start menu ---> setting ---> control panel ---->mouse
in "Buttons" tab select double click speed and check it right side yellow folder open and close when you tapping
Feb 01, 2010 | HP Pavilion dv4000 Notebook
How to repair the left click button on HP Pavilion ZT1135
Hey,
I had the same problem. It is pretty easy to fix. You have one of two options to follow.
1) Push down moderately hard on the left mouse button. After 2 mins or so, and the cap should back on to the button on the bottom
2) if number 1 doesn't work get a needle or pin and lift the left mouse button off. Then just apply very little, not even a drop, maybe half of a drop to the button and apply the cap back on and push down.
Sep 25, 2009 | HP Pavilion zt1135 Notebook
Loose left button mouse on an hp dv4-1120us
If only the one button is loose then touch pad assembly probably will require replacement. This isn't a big job but usually involves opening the case. Two screws and one connector and button it back up. If the laptop is new you should have this covered by warranty. Cost of the part should be about $30-$70 as well as labor.
If you are lucky you might just have a loose fitting button that you can snap back in to place. With the laptop off try to gently push/wiggle the button down. It might pop back into its mounts. If this works (slight chance) then it might work normally for a while and pop out again. It won't have fixed the wear that let it come loose.
Aug 17, 2009 | HP Pavilion DV4-1120US Laptop
Laptop sound not working
troubleshoot for a disconnected wire right below the mouse pad or under the speaker panel. I went through the same problem... it was a disconnection problem. I fixed it myself and never tore a computer apart before. It works great now!
May 18, 2009 | HP Pavilion dv6000t Notebook
HP Pavilion Entertainment PC - scrollbar on mouse pad not working
hi there.
maybe your mouse is not comaptibel with the system of your laptop or you need the disk driver to install the mouse to work properly?
or your mouse is already damage and need to replace try to change it with a new one.
Feb 14, 2009 | HP Pavilion dv6000z Notebook
Left mouse button on touch pad not working
have u tried to check it on the control panel/mouse options.
if its not working though i guess the have reason about that.
Dec 30, 2008 | HP Pavilion dv4000 Notebook
Microsoft HP Pavilion DV6276US Notebook PC Logo
105 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
