Question about Epson Stylus Pro 4800 InkJet Printer
Just powered up this printer and get service error 0001001d
Only just got this printer in, have powered it up and this is the message i get.
  • 33 Answers
What message?
Posted on May 14, 2008
Epson 4000
The error relates to a carriage movement error detected by the printer. This means the printer has detected too much power is required ti move the print head. Reason : All these Service Requests (Service Requests 00010004 , 00010005, 00010006, 00010007, 0001000A, 0001000F, 0001001D) are related to a Carriage movement error that is not automatically due to a Hardware fault. The reasons can be : - The carriage is lock not completely released. - The carriage lock has been partially pushed in after a paper jam or maintenance (for example). Reminder : The carriage lock must be released after unpacking the printer (see setup instructions) as follow : Points to check : In case such an error appears: - Power off the printer. - Ensure the Carriage lock is released (pulled to the left side) - Pushing down the cutter blade, slide the carriage to the left ? At the same time, please check if there is any foreign materials / dust / paper jam in the carriage path. If so, remove them. - Also, make sure that the carriage encoder (T-Fence) isn?t dirty and is correctly set and centered. Let me know how you get on with this info.
Aug 17, 2007 | Epson Stylus Pro 4000-PS InkJet Printer
My Lexmark printer is showing 122.03 service fusher error what can i do
This error normally requires a service call. However, certain rare occurrences, such as a a power fluctuation or a stray static discharge in the vicinity of the printer, can cause a false 122.03 error message to appear. In these cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table to test this.
Step Action 1
Power the printer off, wait ten seconds, and then power the printer back on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the page prints, the printer is functioning correctly. 2
If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Yes: Continue to Contacting Lexmark below.
Contacting Lexmark
Please contact Lexmark Technical Support for additional assistance.
Jun 10, 2011 | Lexmark X543dn Laser Color All-In-One...
0001001D Errore nel Epson Pro 4.450
Fortunately, although you appear to have a spanish language machine, the error codes are all the same- you have a problem with the CR (carriage return) motor- it's up inside at the far left and moves the printhead back and forth with a toothe belt- sometimes it's as easy as cleaning the clear plastic strip that the printhead passes over as it travels- the plastic strip is stationary and the printer has a groove around it - although you can't see anything on the strip, the printhead can and sometimes if gets dirty and fouls up the reading- if that isn't it it's time to buy the service manual or get a repairman-
May 31, 2010 | Epson Stylus Pro 9800 InkJet Printer
103 service ITU ERROR
lexmark basically has said that if this error doesnt clear by powering off the machine and powering it back on again then it will need to have a service call. this error means there is a problem with the itu belt assembly.below is what they say. the steps were to pwoer it off and back on again using a grounded wall socket
This error normally requires a service call. However, certain rare occurrences, such as a stray static discharge in the vicinity of the printer or a power fluctuation, can cause a false 103 ITU error message to appear. In these cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table.
Step Action 1
No:
Nov 19, 2009 | Lexmark C760 Laser Printer
994 Service Density Sensor Error Lexmark C912 Color Laserjet
What the error means:
The 994 Density Error indicates that the printer's system card has encountered an unrecoverable error.
What to do:
This error normally requires a service call. However, on certain rare occasions, such as a power fluctuation or a stray static discharge in the vicinity of the printer, can cause a false 994 Density Error message to appear. In such cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table to check.
Step Action
1 Power the printer off, wait ten seconds, and then power the printer back on.
2 If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Yes: Continue to 'Contacting Lexmark' below.
Contacting Lexmark
When calling for service you will need to know your printer model type and serial number. If you need help locating this nformation, click here.
Call them while you're near the printer in case the technician asks you to perform a task involving the printer.
Jun 15, 2009 | Lexmark C912 Led Printer
Service Call Error 0001001D
Hi poulin,
Click here to access your printer's manual
http://support.epson.ru/products/manuals/000909/spro798400rg_e.pdf
Page 327 on that manual will contain information on how to troubleshoot service errors. On page 115, it talks about adjusting parameters for better print quality.
Hope you may use the manual to troubleshoot your printing errors on your own.
Apr 09, 2009 | Epson Stylus Pro 9800 InkJet Printer
Error 0001001D
Are you still having problems?
Jan 20, 2008 | Epson Stylus Pro 4800 InkJet Printer
Epson Stylus Pro 4800 InkJet Printer Logo
482 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
