Question about KitchenAid Superba Architect KSCS25IN Side by Side Refrigerator
Ice maker mal-formed ice
I have a Kenetico reverse osmosis water system suppling my Kitchenaid Superba side-by-side refrigerator. I believe the water filter in the refrigerator is hindering the water pressure from adequately providing the volume of water necessary to the ice maker to function properly. Is there a replacement "slug" with no filtering available to replace the existing filter # 4396508 as the reverse osmosis is more than adequate for this.
  • KitchenAid Master
  • 2,005 Answers
No "slug" is available however you could just use a reverse osmosis diaphram pressure tank to boost the water pressure. you can also use a water supply tube to bypass the in-refrigerator completely.
Posted on Jul 22, 2010
I removed the filter all together and it runs fine with no leaks
Posted on Jun 21, 2012
KitchenAid Superba KSRG25FK Side by Side-where is the arm of the ice maker?
Hello ksraine,
I understand that you are looking for the arm on your ice maker. I believe you are talking about the ice makers that have the little wire arm that goes up and down as it makes ice to know when to stop making ice. The ice maker that you currently have installed on you side-by-side does not have the wire arm. Here is a picture of a complete ice maker that is factory installed on your unit -justinbur167.jpg Thank you for choosing FixYa.com
Justin
Apr 25, 2011 | KitchenAid Superba KSRG25FK Side by Side...
No ice forming
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jun 08, 2010 | KitchenAid KSCS23INSS Stainless Steel Side...
Ice maker stopped working. water still dispenses but no ice is forming anymore. can you help?
Here is a tip that I wrote about the reasons why ice makers do not work.
heatman101
ghhdg
Feb 10, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid ice maker water overflow issue
it's gonna be either the water valve or the gear shaft in the ice maker. replacement ice maker $130.00 water valve $40.00. gear only comes in with module $90.00. low water pressure from plugged water filter can cause this or if a reverse osmosis system is hooked to it. 40 pounds or more is reccomened for the valve to work properly
Dec 09, 2009 | KitchenAid Refrigerators
WP side-side freezer appears to be overflowing the
You just need a new water valve for this unit. Call us with your midel number and we'll be sure to get the right part out to you right away! We look forward to hearing from you soon.
Oct 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker Not Working
Hi: A lot of reverse osmosis systems don't supply enough water pressure to the ice maker to fill. Contact your manufactrue of your reverse osmosis system and see if it works with icemakers. I thind usually the require at least 20-30psi. Or hook your refrigerator to city pressure to see if it works. Also I don't know if you have just an ice maker or a water dispensing side by side, or your water quality. If you just have an icemaker, most chlorine will evaporate before the ice is frozen, any odors in the water will still be there. Good Luck, Jeff
May 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker does not make ice.
JOEHUNT TRY THE WATER VALVE ON THE BACK OF THE REFRIG BEHIND PANEL MAKE THE ICE MAKER GO THROU A HARVEST OR JUST WAIT TO HEAR IF IT GOES THOU A HARVEST THEN YOU CAN SEE IF (1) YOUR ICE MAKER IS ACTUALLY WORKING OR YOU NEED A WATER INLET VALVE ITS 1 OF THE 2 MOST LIKELY THE VALVE
Apr 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba ice maker stopped working
the oil in the compressor has pumped up to the top hence the ice is not formed the lead valve in the compressor is not working properly so change the lead valve and you could make ice as before
Jul 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
No ice
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jun 23, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Nov 10, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25IN Side by Side Refrigerator Logo
272 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
