Question about Canon PowerShot SD950 IS Digital Camera
My canon SC950S won't turn on. The battery is charged and I tried pushing it in as one of the solutions on this website said to try that. Nothing works. Please advise do I just need a new camera?
  • 22 Answers
SOURCE: Canon Poershot sd300 digital elph. It just wont turn on period.
Try this: with the battery installed and battery door open, take a pencil, fine tip screwdriver, or anything long and skinny and push the tip of it into the little nub circled in the picture here. There's a spring inside that little nub... keep the spring depressed and try to turn on the camera. If it works, then either a small piece of plastic broke off the battery door or the nub got broken/pushed in too far for the battery door to trigger it. Try using a dab of hot glue to keep the nub pushed into the down position.
Posted on Apr 10, 2008
SOURCE: Replace battery sign in New canon A590si camera.
You're using the wrong batteries. You need to purchase lithium batteries. They are quality batteries for high powered, battery operated electronics. Personally, I have a battery charger and use rechargable duracell batteries. (HR6/ DC1500/ NiMH/ 1,2V) Gives you approximately 16 hrs before having to recharge.
Posted on Dec 08, 2008
mannforever
  • 23 Answers
SOURCE: Camera will not turn on. Battery fully charged;
You can give it to an expert for repair, he can repair it for less as there must be just a fuse problem, which can be fixed for a very less amount.
Posted on Aug 11, 2009
chelseawells
  • 11 Answers
SOURCE: will not turn on
This is likely the cause of an internal screw that has come loose, it's very common on the G9. A great place to get help with this G9 problem is: camerasandparts.com since they just specialize in these powershots. They not only have the fix available but they have the correction so this never comes back, that comes with their no power service for the G9's automatically. I hope that helps, that's the place if you need help with a powershot, best of luck
Posted on Jun 24, 2010
ginko
  • 19396 Answers
SOURCE: Canon EOS 1000D - when
Hi.
Hi. First ensure that the power adapter is OK.
The power adapter should have been tested using a multimeter (see Multimeter)
If the adapter was good it would have read no more +_0.5V difference from the value in specification.
If the adapter is good, test different batteries. If you do not have a spare battery pack, then you can go to a Canon camera shop and ask to test a battery on the bench.
If the battery and the charger are not the problem, then there is an internal failure preventing the camera to start.
The problem is internal. The most common occurrence is a faulty printed circuit board. A short or a broken contact in the power ribbon cable are less common, but will give the same symptoms.
The EOS must be disassembled and tested to find the problem.
If the unit is over one year old you can ask an online quote using this link:Repair.
I also suggest contacting Canon to check warranty terms and ask a quote on repair.
Regards.
Ginko.
Posted on Mar 21, 2011
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
New unlocked cell phone won't turn on
Hey, same problem. Push and hold the hangup button. It will prompt to insert sim , but I only have one. The phone works. The website and the manual are useless. Just gotta play with it, I guess.
Mar 06, 2013 | Cell Phones
Canon powershot SD1300 IS won't turn on, even with fully charged battery
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Oct 11, 2011 | Canon PowerShot SD1300 IS IXUS 105...
I have a Canon PowerShot SD600 Digital Camera. The battery has a full charge but the camera will not power up. I press on and nothing happens. What do you recomend?Best RegardsNeil
Oct 02, 2011 | Canon PowerShot SD600 Digital Camera
My Canon xti stopped working at my son's graduation. I had a full battery and took a few photos.....then turned it off.....and when I turned it back on again, it was completely dead. Tried several...
Hiyou might have a problem of either main pcb or power control pcd (dc/dc convertor). it is common but it cost. It cause usually come from loosen screw going around inside and short. If it is lucky, then your unit would just a fuse brown. If not, it has to change main pcb and all of computer adjustment is involved. Your local repair shop would charge you around $65 to 235.
Jun 04, 2011 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EOS Rebel problem
This is usually caused by a defective shutter release switch - it'll have to go into a repair shop - independent shops will charge about $110 USD - Canon charges about $180
Nov 26, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
My Cannon G9 digital camera wont power up even though I have a fully charged battery?
This is usually from a loose screw inside the camera, a screw inside the camera can come loose and cause a short which is very common on the G9. If you go to: www.camerasandparts.com all they deal with is service for the Canon Powershots. They're great if you need a hand with one of these and they automatically do the no power correction on the G7's and the G9's they service which is nice. They are about the least expensive out there at $89 and they include the service and the shipping back. The best part, they do excellent work which is a must for me. Hope that helps you some.
Aug 17, 2008 | Canon PowerShot G9 Digital Camera
Apr 04, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Lifeless Camera
I wish I shared you easy solution feeling. Try a few things Take battery out and clean the contacts at the base of the chamber with a pencil eraser. Ditto on the chamber door. If nothing happens try charging the battery in another charger or another battery. Still dead? Kodak support is the next stop
Sep 19, 2007 | Kodak EasyShare Z612 Digital Camera
Canon PowerShot SD950 IS Digital Camera Logo
317 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
