Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
I hear the motor but know movement. I have tried the reset the allen wrench and putting the hand down in to clear and Nothing. Can you help
    Sergeant:
    Champion:
  • 277 Answers
NEVER put your hands in that unit
There usually near the neck of the garbuator is an access hole to use a screwwdriver, with the power off, to loosen the impeller
Give that a try
Posted on Jul 22, 2010
Ok my ace 2000 disposal hums. blades move freely when i put my hand inside. the 1/4" allen wrench doesn't fit in the opening at the bottom. my sink fills with water but eventually drains, so I...
Sounds like the starter winding is bad.
The cutter disc is welded directly to motor shaft. So is the allen wrench fitting.
So if disc rotates freely, then you should be able to feel the allan wrench fitting rotate too.
Use broomstick instead of hand down disposal.
If motor hums and cutter disc does not spin, but cutter disc can be moved freely, then disposal needs to be replaced.
I wish they made repairable motors so that metal and copper doesn't get thrown into the scrap recycle metal bin.
I wrote ez disposal replacement tips:
http://beta.fixya.com/support/r7929008-replace_garbage_disposal
Oct 03, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage Disposal Ace 2000 model 47982.... The water won't drain out of it and the sink is backed up and hasn't gone down for a whole day now. It seems like the blades are turning. I've been...
Hi David,
Are the blades actually turning or is just the motor running?
First, turn off the power to the disposal at the circuit breaker. Do not put your hand in until you do this.
If you hear the motor running, but not the blades, then the blades are jammed. On most disposers you can put an allen wrench in an opening under the unit and move the blades. If the blades move freely, then your drain line is probably plugged.
If the motor runs, but the blades don't and they will move freely by hand, then the disposal needs repair.
If the blades are jammed with food, you can clear the jam with your hand and the allen wrench trick from underneath.
Once the disposer is freed up, run cold water down the drain for a few minutes to harden any grease build up inside. Then running the disposer should get rid of the hardened grease.
By the way, most disposers have a reset button on the bottom of the motor should your disposer jam and turn off or trip your breaker.
Orange peels, etc. will not harm your disposer. A good way to keep it clear is to put egg shells down it periodically. The shell action will scrape junk off the inside of the disposer.
You can also keep the disposer clean of grease buildup by pouring some baking soda in the disposer followed by a mix of hot water and vinegar.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 06, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Need to know when removing a chuck from a drill is it clockwise or counterclockwise?
The retaining screw at the bottom of the chuck ( down inside where you put the drill bit) is reverse thread. the chuck itself is regular thread. Take out the retaining screw, chuck a 3/8 inch allen wrench ( short side) into the chuck just like a drill bit. Lay the drill down on a work bench with the chuck pointing towards you and the allen wrench clear of the table. Hit the allen wrench with a hammer, ( may take a few tries) in a counter clockwise direction. the chuck should unscrew.
Nov 17, 2010 | Milwaukee Tool Drills
I have a Badger Insinkerator Model 5-81A. I put some asparagus ends into it to dispose of them. They were ground up but water is now coming back up when I turn it on. I have lost the directions and...
yes that is right. keep turning the allen wrench untill it turns easily. then push the reset hard and try it. you dhould hear the unit run. if its running and you still have standing water, the the drain lines have plugged.
Oct 22, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Humming noise when turn on, but blade/motor not moving. Tried reset button and turn the motor with allen wrench. What else can I do?
its stuck, is it still under warranty. either the motor is bad or something is jammed in there. you need to turn the blades by hand or allen , if nothing, then the motor is somehow bad, need to replace.
Mar 30, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Disposal hums but doesn't rotate. I would like to know where the reset button is so I can see if that is the problem. I've tried turning the inside mechanism but it won't rotate...
There are several things you can check. First make sure the unit is off and check for debris stuck inside the unit. On the bottom of your Disposal is a slot for an allen wrench also most have a reset button here also. First take the allen wrench and turn the unit around several time manually before you do anything else. Now run some water down the unit and see if it will turn on. If it doe not try the allen wrench one more time and do the same as above. Now try the reset button. If this works great because the next step requires you to take the unit off. Let me know if this works before we go to the next step. Hope this helps.
JimmyC
Oct 08, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Chuck on Bosch 1194 vsr drill is rusted... how to remove?
you are half right. The screw that you see is a chuck retaining screw (LH thread) to keep the chuck from loosening up when in reverse. What you need to do is if you have one remove it first and then find a bent handle allen wrench about the size of the chuck capacity, lock the shorter end in the jaws and then position the wrench at about a 30 deg angle and put the chuck on a block of wood or bench and take a hammer and hit it counter clockwise. If you have a wrench small enough to lock onto the spindle use it and brace it on the bench. If this tool has a high and low setting use the low and if clutch equipped the drill only. Let me know if you need more help
Jun 26, 2009 | Bosch 1194AVSR 1/2" Vsr Hammerdrill
How do I remove a keyless chuck from my Sears drill.
The chuck is screwed on with a normal thread, the screw in the centre (already removed) is left hand thread. Holding the drill with the open end of the chuck facing you, it should unscrew anti clockwise. It might take an impact to start it off. I normally put the gearbox to slow, set the cluth to drill and then holding the drill firmly, hit the allen key against the edge of my workbench. Bring the drill down like a hammer blow so the allen key hits the bench (which should be on your left). I find this more effective than holding the drill on the bench and hititng the allen key with a hammer as it allows for less drill movement at the point of impact.
Nov 14, 2008 | Drills
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
282 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
