Question about Toro Garden
I have a toro personal pace gts self propelled. only model number i foind was 2h802. pull cord broke, would like to know how to replace it
    Guru:
  • 630 Answers
You can buy the whole part...cord,handle,recoil spring all in one piece and remove the old install the new...or you can just buy a legth of pull cord and swap everything over.
First take off the top 4 phillip screws and remove the plastic cover....don't forget to pull off the oil fill cap, next drill out the center of the three pop rivets that hold the recoil spring in place, use a drill bit a little smaller than the rivet, next tap the rivet out using a punch and a hammer, next install the pull chord by first rewindind the coil spring then locking it oin place so it wont twist back and install the new line(pull cord)...next install it on the top of the motor and install 3 new 1/4" aluminumn pop rivets 3/8" long with a pop rivet gun all can be purchased atb Ace Hardware...reinstall the reverse of dismantle proceedure and happy mowing...don't forget to attach the black plastic/rubber pull cord handle.
Happy Mowing!!
Posted on Jul 22, 2010
Why do the wheels lock up on my self propelled 22" recycling mower
Sounds like they need cleaning & oiling. Check that nothing is keeping it from moving. I have ran over string or cord before & got caught and wrapped around wheel.
Oct 27, 2014 | Toro 22 in. Personal Pace with Blade Stop...
I have a Toro mower made in 5/09 self propel system it grinds when you pull it in reverse. The selp propel is not working. The belt is on. and it seems to be only the left rear wheel? The cable is not...
Yes it is the transmission. A Mower shop will charge you about $225 to fix.. I order parts online and fixed mine for $90. Transmission consist of 3 gears which turns the rear wheels to self-propel.
Jul 21, 2014 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro gts 6.75
you will probably need to replace the tabs that pop and grab the fywheel, the springs should be replaced as well.
Jun 15, 2013 | Garden
Replace right rear hieght adjuster on a toro self pace mower
Remove wheel, remove screws mounting adjuster, straighten or replace.
Oct 02, 2012 | Toro 22 in. Personal Pace with Blade Stop...
Toro 2009 personal pace mower transmission went out
You should post this question in the lawnmower section so the proper expert will see it..
Aug 29, 2012 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro model 20038 self propel problem
Try taking the back wheels off and lubricating the joint cogs and wheels with ,say, 3 in 1 oil . The dealer recommended doing this once every couple of years as preventative maintenance when I bought mine , and it has solved sticking problems for me .
Sep 12, 2009 | Toro Lawn Mower With Toro Power Tools
Self Propel Cord Replacement too loose!
measure it from the old cord thats the easiest way ?
Aug 26, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Personal Pace self propel problem.
Your self-propel is probably belt driven. Belts can make an awfully lot of noise when unhappy. Possible it has rolled over and is running on the wrong side of the belt or is worn and just needs replaced. Hope this helps.,
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
SELF PROPELL NOT WORKING GOOD
Have you checked the belt that drives the wheel? This is more than likely the problem. It may be broken.
Jim
May 30, 2009 | Toro Garden
Garden Logo
636 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
