Question about M&S Systems MNC System
My M&S System has experienced
My M&S Systems MC602 intercom/radio has experienced "ghost" audio when the audio system is turned off, e.g., faint sounds like audio interference can be heard through speakers.
    Problem Solver:
  • 7 Answers
My M&S 302 also had similar problem.
sometimes it will turn on and turn off by itself.
I believe it is sensitive to signal and noise or signal cross-talk.
Once I pressure washed the window, the M&S system created
strange sounds. I think the wiring in the window frame gets wet and caused it. This system is very sensitive.
Posted on Mar 06, 2011
Buzzing or static noise on AM radio; is there a fix?
AM radio signals are very susceptible to what is called spurious radiation that is to say for instance high power electrical lines, noise from the car's electrical system like the alternator and the ignition system. I would have to hear the noise to know which you have. You also may just have a defective radio. Check one thing make sure the antenna is well grounded to the chassis of the car where it is mounted.
Jun 10, 2016 | Cars & Trucks
Have M&S systems Model MC602 Can't seem to reset after power outage.
I called the company and this is what they said:
Based on the problem description, there is nothing you can check to try and get the radio to work again. The most likely cause is a Tuner Module failure due to electrical surge. You will need to send the MC602 to us for service. We will need you full address, phone number, and the serial number or date code from the back of the MC602. The serial number/date code will be on a white sticker and may have a barcode on the sticker as well. When receive you information, we will issue you a Return of Product Authorization (RPA) number and instructions for returning the unit. There will be a repair charge and that can be provided with the RPA number.
Sincerely,
James Williams
Senior Applications Engineer
Linear LLC
Technical Services
(800) 421-1587
Sep 23, 2010 | M&S Systems Audio Players & Recorders
My radio on the mc602 stopped working. The entire system still works except for the radio. any ideas?
sounds like a internal fuse look in your manual and see if it may have a heatsink switch that disables the radio if the heat levels get too high.
May 27, 2010 | M&S Systems M & S SYSTEMS DMC1CDB Whole...
I cant recieve any stations on my mc602 intercom after power outage'' the light works and the system turns on but all stations are static.
You prpbably have to rescan for stations and enter them into the memory. If the unit is old, the battery may be depleted... in that case replace it first.
May 24, 2010 | Music
M&S Systems, #MC350A, central intercom system, malfunctioning
I'm having the same problem. I think LIST means it is in LISTen mode, listening to the outside door station. Why it is doing that is unclear.
Oct 18, 2009 | Audio Players & Recorders
MC602 intercom system locked up
I don't have a solution, however, I do have the same problem. When it happened originally, I smelled electrical wires burning. someone checked it and said that a wire had shorted. The electrician checked it out but could not find out what was wrong with it. The radio comes on, but we cannot use any of the buttons.
Sep 03, 2009 | M&S Systems M & S SYSTEMS DMC1CDB Whole...
M & S MC602 intercom system locked up
Mine does the exact same thing, except mine isn't set up to change stations from rooms..did you ever find a fix?
Aug 09, 2009 | M&S Systems M & S SYSTEMS DMC1CDB Whole...
M&S Systems MC602 Master Unit and M&S MCD6 6-disc CD Player
mc 602 system---volume stuck on 32 and not playing main speaker
Mar 05, 2008 | Audio Players & Recorders
M&S Systems MNC System Logo
315 people viewed this question
Top M&S Systems Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Tre Elkins
Are you a M&S Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
