Question about Linksys WRT160N Wireless Router
Can't get laptop on wireless
Using the WRT54G2 My main computer is on the internet fine. I can connect to the wireless network but can get on the internet
  • 4,281 Answers
You are able to connect wireless but not accessing the internet because of wrong WAN or lan settings. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then clickon WAN settings and make sure settings are correct as your internet service provider settings. If you have static ip from ISP then configure as static ip enter all ip and dns but if you need user and password for connect internet then configure as PPPoe then enter user and password then save settings and restart router then check.Also enable DHCP on router then in tcp ip property of your wireless network as get ip automatic then check. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Jul 22, 2010
  • hrubyca Jul 22, 2010
    Everything was working fine this morning. I have a home pc and two laptops hooked up with wireless. My internet went down and now I can't get the two laptops back on wireless. I unplugged everything and rebooted. I can connect the laptops to the wireless but can't get on internet. I also can't get to the router. I tried all the urls and even my gateway ip.
  • If you are not able access router with defaults ips then press RESET button for 10 seconds it is in back side of router then all settings defaults then try to access it with default ips.
My WRT54G2 will not connect to the internet I am using another router also
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 18, 2010 | Linksys WRT54G2 Wireless Router
How to find security code for linksys WRT54G2 to
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here
for step by step Instructions on how to find the network key
Jan 28, 2010 | Linksys WRT54G2 Wireless Router
Can't install linksys wrt54g2 router with arris tm602g modem
I've tried network magic and everything thing else and I still can't get it to work.
Sep 28, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys wrt54g2 router not allowing connection wirelessly
U can try reset the router back to default factory mode, then reconfigure again...
Mar 08, 2009 | Linksys Wireless-G WRT54G Router
Linksys WUSB54GC Connected to the Network But No Internet
I got me a Linksys and had the same problem, if solved this bij flashing the router with a new firmware.. and now it okee for a long long time..
Do you know how to do this?
let me know
Gr Rich
Jan 08, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Connecting wireless router to laptop computer
Try changing the channel on the router. It would be better to isolate the problem first by trying to connect to other wireless networks on your laptop or having someone's laptop connect to your home wireless network.
Sep 03, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
No internet access
Check if the wireless network is connected properly in the laptop, try to disconnect the connection , and reconnect again ..if you still feel you are connected..at the lower right hand corner you will find the wireless network connection icon..right click the icon and click view available wireless networks, check you are connected..if yes click change the order of the preffered networksand remove your wireless network and then try connecting it..try it out and let me know...all the best
Jul 29, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Wireless router, laptop problems
Try to delete all the prefered networks. Right-Click Wireless Network Connection, View Available Wireless Networks. Click on Change the Order of Prefered Networks. Remove all prefered networks there and click OK. Now try to View the available wireless networks again, reconnect to your own wireless network and see if it connects fine. Post your feedback.
Jul 12, 2008 | Linksys Wireless-G WRT54G Router
Laptop problems
Does this mean that its the laptop that can't get a wireless connection? Just want to clarify before giving out more steps that you can try.
Jul 12, 2008 | Linksys Ultra RangePlus Wireless Routr...
Cannot connect to the internet with my laptop
To connect to the router wirelessly using a Windows XP, right click on the wireless network connection icon on the lower right corner of the screen and choose view available wireless networks. Select your existing network and click on the connect button. If you are using Vista, go to network and sharing center of your control panel then select connect to a network. If you still having problems, please provide details of the problem like your Internet service provider and if there are already other computers online with your WRT54G2.
Jul 11, 2008 | Linksys Ultra RangePlus Wireless Routr...
Linksys WRT160N Wireless Router  Logo
61 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
