Question about Westinghouse Turbo Swirl 78145 Ceiling Fan
Replacing 3-speed fan swith, using westinghouse 77021. Black (hot wire) to L, red to 1 , outer black to 2. What is 3 STRIP for?
    Sergeant:
    Champion:
  • 277 Answers
The third wire should be for neutral (White) This is an incomplete request,
Is this a three wire pull switch or are you hooking up to a light switch on the wall.
but what I know is Black hot
Red switch
white neutral
If it is NOT WHITE do not attach it untill you have someone over to help you
Posted on Jul 22, 2010
I have a harbor breeze ceiling fan on a dimmer
You have 3 options. You can connect the fan blue and the fan black to the red ceiling wire. Then you will need to control the fan and light with the strings. The wall switch will turn off everything. Option 2 is make sure that there is a switch wired to the black ceiling wire. If there is a switch I would check to make sure the switch is working. Option 3 is to purchase a remote control unit for both and leave the wall switch to shutoff the whole unit. Hope this helps.
Oct 11, 2013 | Speed Ceiling Fan 3-speed Switch By...
I have a westinghuse fan with light it has four wires on it green, blue, black, and red what are they ie live neutral etc
Question posted under 3-speed switch
1) Are you replacing the 3-speed switch?
This is a field with much discussion because Westinghouse 4-wire fan switches vary.
Process of elimination is needed to find hot line. From there you test each wire to the hot line wire to determine which wire or combination of wires makes up low, medium, and high speed.
Open following links for some resources:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php
http://www.atlantalightbulbs.com/ecart/catalog/westinghouse-6.html
2) Or are you looking at fan connection wiring at ceiling?
Green wire goes to bare ground.
Fan should have hot and neutral.
Hot line should be black.
Neutral should be white.
Red usually goes to light
Blue is normally not there.
Where is the white neutral wire?
Take multimeter set to read ohms and test black wire to each other wire.
Process of elimination should reveal correct wiring.
Aug 21, 2011 | Speed Ceiling Fan 3-speed Switch By...
I have a Hampton Bay ceiling fan. I bought Westinghouse 77021 to replace the fan switch. I have black, white, yellow and blue wires inside the fan's case. Where should I connect these wires? Jane
Hello. Yhe most common combination for this wire combination is: L - White, 1- Black, 2 - Blue, 3 - Yellow . However this is assuming your 77021 (the fan) has three speeds and the pullchain has four wires. Here's a link to some very good troubleshooting advice: http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php
and a link to Diagrams: http://www.hurontel.on.ca/~taitg/pages/cfan.html
Hope this helps, and don't forget to rate our help. Thank you.
Mar 07, 2011 | Speed Ceiling Fan 3-speed Switch By...
I have a 3 speed fan switch that i am replacing, b...
Hello. I really hope the 2nd grey is simply a faded purple or green. The most common configurations would be: L - Black, 1 - Grey, 2 - Brown, 3 - Purple or green. Here's a link to some troubleshooting advice: http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php and a link to diagrams: http://www.hurontel.on.ca/~taitg/pages/cfan.html
Hope these help clear up that nasty faded color for you, and don
May 21, 2010 | Speed Ceiling Fan 3-speed Switch By...
Westinghouse Lighting 3speed Ceiling Fan Switch 7707500: I just replace the speed control switch in my Hunt...
Typically the old and new switches have no relative relationship to each other .. One way to figure this out is shut off the power and then using the black power wire attach each speed wire to it and turn power back on to observe the speed .. mark the wire with the speed 1, 2, 3, .repeat this untill all the wires are identified .. . then you can put the wires on the appropriate terminations on the new switch ..
questions ..
Please vote !
May 17, 2010 | Westinghouse Electric Westinghouse...
I don't know witch wires go where?
Hello. The most common configuration is: L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
Apr 15, 2010 | Speed Ceiling Fan 3-speed Switch By...
Changing the 3 speed switch on my westinghouse ceiling fan
If you are careful and take the hot coming into the fan from the power source and connect it to the colored wires one at a time, you will be able to find which one is high, med. and low. Then connect them. Hot in is L, 1 is low, 2 is med, 3 is high
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 18, 2009 | Speed Ceiling Fan 3-speed Switch By...
Westinghouse Turbo Swirl 78145 Ceiling Fan Logo
284 people viewed this question
Top Westinghouse Dryers Experts
Naveen Sistla
Naveen Sistla
Level 1 Expert
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
