Question about Magellan MAESTRO 3100 98083401 GPS Device
While using our GPS it stopped working; unplugged and plugged back in and the screen would not come up
    President:
  • 1,111 Answers
Hi clarkm
this is a very common problem with your model gps
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Posted on Feb 10, 2011
Garman 225w won't start, stops after "loading
The micro usb port is at the back. Connect Vehicle Power Cable to the nüvi and connect the other end to your computer, your nüvi does not operate as a GPS unit - it goes into some sort of charging mode. However, if you FIRST turn on the nüvi in the battery mode then go into the test mode (press the battery icon for about 8-9 seconds) from the main screen, THEN PLUG in the USB cable, and finally exit the test screen, your nüvi will restart (reboot) and it will operate just like it was plugged into the cradle connection in your vehicle.
This mode will charge the battery
AND operate as a GPS.
It works with my computer USB cable, my cell phone charger and my car charger for my cell phone.
Don't forget to turn off the nüvi before unplugging.
Jan 08, 2011 | Garmin nuvi 255W GPS Receiver
Garmin 1200 screen is too dark to read when plugged into my car with the supplied Garmin connector. When I unplug from the car and turn it on the screen works, plug into car doesn't work. I just was on a...
I would go to Tools....Settings...Display.... check your Color Mode is it check on Auto...Daytime or Nighttime pick one then press OK
On the Brightness press it to set it brighter or darker then press OK
Oct 30, 2010 | Garmin nuvi 1250 Car GPS Receiver
Screen frozen, button and power button do not operate,
Just unplug it and let the battery die out. Then after is shuts off plug it back in and start it up. Annoying process but it's all that will work at this point.
Feb 06, 2010 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi 200W car cable fell apart. Bought new universal cable which charges gps in car but screen will only show a symbol (looks like a cable plugged into a computer) that's not explained anywhere in...
i have gone through more cables than you can imagine, if you plug in the cable that gives you the computer symbol,slide the power button to what would be the off position then slide it back to lock
1 or 2 slides should take it out of this mode, i had the same problem.
Feb 04, 2010 | Garmin nuvi 200W GPS Receiver
Touch screen stop working
Omnitech GPS systems are very decent for me. I have 2.
There were several reports of GPS problems beginning on or about 11-14 June 2009. This is due to the GPS navigation messages rollover from 255 to 0. Some GPS systems fail to accommodate this behavior; Omnitech is one of them.
Staples did provide a firmware update a few days later. There are also other firmware updates available on the net. I personally successfully update the firmware and resolve the problem around June 15, 2009.
Otherwise, the problem should go away after 1-2 weeks.
thsquare
Jul 12, 2009 | Nextar Q3 GPS Receiver
New Nuvi 200 will turn on briefly then turn off.
You need to charge your gps from any external charger and check whether screen is working properly .
Also do firmware update for your gps .
By updating firmware your problem can be fixed .
Jan 22, 2009 | Garmin nuvi 200W GPS Receiver
Navigon 5100 gps
Try turning it off and turning it back on while it is still plugged in and see if that works.
Oct 23, 2008 | Panasonic Navigon 5100
Problem when receiver is plugged in to charge.
Are you using the charger that came with the unit? If you do not use the one that came with it, the unit may be reading this as though it were plugged into the computer. It will charge then, but will not operate unless unplugged - just as you are describing.
Aug 12, 2008 | Garmin Nuvi 660 GPS Receiver
Voice stopped working
Do you use the plug in adapter with the speaker in the plug?
Check it, there is a small volume wheel on it, probably sent it to zero whilst unplugging or plugging it....also check if the power plug is fully seated in the GPS
May 20, 2008 | Garmin StreetPilot 2720 GPS Receiver
Stops working when unplugged
Check the auto turn off settings, could be a power interuption
Jan 07, 2008 | Garmin Quest GPS Receiver
Magellan MAESTRO 3100 98083401 GPS Device Logo
43 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
