Question about Philips AZ1574 Cassette/CD Boombox
It's saying "cd open" when the cd thing is shut? Tape works, but I can't get the cd to do anything. help?
  • 3,083 Answers
The CD player has a sensor-switch, that the cpu isn't getting a signal from. The switch could be dirty, worn, or broken. The switch will have to be inspected. You might try blowing some compressed air into the switch. If that doesn't help, the switch will have to be checked out first, then the unit will have to troubleshot further, in case the switch proves to be good. Hope it's just some dust in your switch. otherwise the unit will have to be serviced. Get an estimate before having it serviced, since the labor can run a bit of money.
Posted on Jul 22, 2010
Sony vaio Desktop Windows XP. Turns on but never actually starts up goes to screen where you can start safe mode, and other choices. None of those work. Took to Best Buy. Tech says Windows corrupted need...
Hi the best thing to do...is press and hold delete when the laptop is starting up,and go into the bios,and make sure that the 1st boot device is you cdrom,after you have enabled that to be your 1st boot device then press f10 and enter..then your laptop will reboot...
open up your cdrom,insert your operating system,then press the laptop power button to shut it down then power it back up...then hopefully it will prompt you to make a fresh install..
Hope this help and if there is anything else i could help you with..
Regards
Apr 02, 2011 | Sony Computers & Internet
Radio working but CD isn't
how long have you had it?......is the cd burnt?....................does any cd work?.................maybe there is short or some thing, if you just bought it take it, or maybe u should replace it
May 08, 2010 | Sony Audio Players & Recorders
Tape deck and cd changer will not work (1999 Ford Escort ZX2)
Wiring, schematic, electrical diagrams, fuse diag, error codes,
torque settings etc are basic contents of these online books they have here on this website www.reliable-store.com I have attached. Must check it out
Feb 28, 2018 | 1999 Ford Escort
Same thing
this unit needs a mechanical alignment, I have worked on enough rca's to last a lifetime...the cd tray is not chucking properly//it should load and you should hear the cd mech chuck down..if it is not chucking properly..it will open randomly..you can fix this by jamming it shut with the power off
Jul 28, 2009 | RCA RS1289 Shelf System
Discs stuck inside CD Player. Screen says ''Reading.''
Try resetting the CD (Cambridge soundworks) by unplugging, then repluging. Then hold down the eject button while you turn on the power.
Nov 15, 2008 | Cambridge Soundworks 740I CD Player
Onkyo six CD changer stuck closed, reads "Mechanical Error" in window...Also, new Onkyo tape deck TA-RW255 tape stuck, won't open and won't turn off.
The Onkyo CD changer has an internal mechanical problem that could be anything from a disc being jammed in the mech, to a bad belt, or a bad IC or supply voltage that goes to the servo circuit. No way to be certain without troubleshooting it. You can open it up and see if a disc is stuck, but unless you have some experience in this sort of thing it is better left to a professional, You can cause more damage than you started with by trying to fix something you don't know that much about.
The tape deck could have any number of problems as well. A bad belt or gear, a defective servo circuit, and the list could go on, but they are all things that also should be checked by a professional.
Most of the time a tape won't eject is form the tape head being engaged and not letting loose of the tape. But since it won't turn off, you have some more serious problems. That is an indication of something not communicating with the microprocessor. It could be a digital transistor, a shorted capacitor, and like before, many other things. Whatever you do, don't force the tape deck open. It will destroy the head assembly and it may even void your warranty (you did say it was new).
You need to find an authorized Onkyo service center near you. Contact Onkyo if you can not find one yourself.
This really is the best action you could take. Onkyo is a very good brand, and in most cases is worth getting repaired. If it were some type of cheap-o brand it wouldn't matter what you did to it because replacing it would always be cheaper than paying for a repair. That is not the case with your equipment.
If I can be of further help, just ask me.
Dave
Jun 28, 2008 | Onkyo Audio Players & Recorders
VCR
you have probably bent the tab that holds the tape end sensor or its light. The tapes have a clear section at the end of the tape and the light shines through to the sensor to tell the unit that the tape is finished. The light should not pass through the recordable part of the tapes. If anything is bent the light may shine on the sensor and tell the unit you're at the end of the tape and to shut off. Some units have a tape tension sensor also that tells the unit that the tape is broken and to shut off. Only way to know is to remove power and take it apart and look for anything that may be bent. Stay away from the rotating head assembly and the posts that the tap travels on. Do not apply power with the unit open. Do not load a tape and remove power as some units freeze in the loaded position and will not load new tapes unless manually placed back in the unloaded position.
Oct 17, 2007 | Emerson EWR20V4 DVD Recorder/VCR
HI I have a DPX-4010 lights up but no sound,
You mentioned that the display says ALL OFF..and if that's the case just press the source (SRC) button until the display says either TUNER TAPE OR CD!
Oct 06, 2007 | Kenwood DPX-400
Insert the tape
There are a variety of things that can go wrong. The process of elimination starts by taking the 2 screws out of the cover and removing. While the compartment is open, push the eject button and observe if there is any motion with gears or not. The main cam gear should rotate a few degrees in one direction and then back. If you see no motion at all then you have problems that are going to require real work. Most often when this is the situation, this main gear, which doubles as the mode switch, is broken and this is a sophisticated repair to replace.
Jun 26, 2007 | Sony Handycam CCD-TR416 Camcorder
Tape will not eject, and reset button does NOTHING!
I am having the exact sam problem on my PV-GS14. Have you been able to resolve the problem? If you have, how were you able to get the tape out? Thanks
Nov 13, 2006 | Panasonic Palmcorder PV-GS14 Mini DV...
Philips AZ1574 Cassette/CD Boombox Logo
69 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
