Question about Refrigerators
Kitchenaid side by side refrigerator Model KSC23INWHOO purchased 7/11/05 When then compressor has been running, vibration begins in back of freezer compartment.
  • 121 Answers
There is a fan behind the top back panel. The blades must be bent or unbalanced
Posted on Apr 22, 2008
Kitchenaid side by side model #DS 110022-RN refrigerator. The refrigerator side not cooling, air flow through top vent almost non-existent. The freezer side is at 0 or below with a very strong blow. The...
Either you have a defrost problem blocking airflow to the fresh food section or you have a blockage in the vent. You're going to have to unplug the refrigerator look in the back of the freezer and see if there's ice build-up on the rear wall of the freezer. Try again with that model number I do not believe that is the correct model number it should have Mod: before the model number.
Appliance 911 Sea Breeze if your refrigerator has an additional cooling Zone in the fresh food compartment you may have a damper that is stuck open but I'm going to have to have the correct model number to help you
Jun 21, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Freezer not freezing ,fridge not cooling ,no ice build up around coils.what should i check for next?
Is the Compressor Running? Put your hand on compressor and see if you feel a vibration or if it is cold or hot. On the side there is a start relay. Remove that and shake it. If it rattles then it is bad. Replace and you will be running again. If compressor is running then most likely compressor is bad. Check frost pattern on the evaporator in the freezer section. If it appears that compressor is running and the evaporator is a little cold and maybe even has a little frost on the top of it then compressor is insufficient,
May 14, 2010 | KitchenAid (KSRD22FKST) Side by Side...
We purchased a new KitchenAid Side by Side Refrigerator Model # KSRG25FVBL01 that makes a loud knocking noise accompanied by rattling from the date we purchsed. We are getting runaround in getting it fixed...
The knocking noises heard from the Freon moving through the sealed system are perfectly normal and usually do not last long. Since the evaporator coil is mounted in the freezer section, the noise is usually louder there. Some people say it sounds like marbles knocking together.
Refrigerant (Freon) moving through the system can cause a vibration/rattling, especially as the compressor first starts up.
  1. Vibrating from top of cabinet Remove, rearrange or pad any stored items atop the refrigerator such as houseplants, coins, pens, etc.
  2. Vibrating from back or sides of refrigerator Move refrigerator away from water line in the rear or away from walls / cabinets along the side of the cabinet. Refrigerators with a static condenser on the back require a rear clearance of 3 inches across the top of the condenser.
  3. Vibrating from the bottom of refrigerator Level refrigerator so all 4 rollers / feet rest solidly on the floor.
    Hope this works.....
May 01, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Amana Double Door refrigerator not freezing in the freezer side.
sounds like a leak ,as long as the compressor fan is running it is a leak. it can be fixed by a technician only due to the tools needed for the repair. these tools cost well over 1000usd and may not be worth purchasing for a single repair.
Phil
Jun 10, 2009 | Refrigerators
Warm refrigerator
Check the freezer fan.
Is it running?
If not, replace fan motor.
Check the damper doors in the fresh food side.
Does air flow through?
Mar 08, 2009 | KitchenAid Refrigerators
Compressor not running
you can try to repalce the "overload relay", with the model numberlook up the correct part. i would also check with oyour manual perhaps you have an extended warr. on your compressor assembly( comes with a new overload relay)..
Mar 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice build up on coil inside freezer
it can be two things the refrgerator probably has a small refrigerant leak therefore it ices up, or the defrosting heater on the begining of the coil is faulty.
Feb 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool side by side, blowing hot air on both sides
First, you must determine if the compressor is running. The compressor is located at the bottom of the unit in the rear. Feel for motor heat and slight vibration. If it is cool then the problem may be an inexpensive start relay. If the compressor is very hot, the start relay could also be the problem or the motor has seized. Find the wiring diagram in the rear of the unit to replace this relay which should be availible at your local refrigeration supplie house.
Ray
Jan 05, 2009 | Whirlpool Refrigerators
hi thanks for the question is the compressor running . pull away from the wall remove back cover and check the compressor if its hot and running with no cooling you have a failed compressor thanks the appliance doc
Sep 26, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
