Question about Car Audio & Video
The radio works the speakers don't emit sounds. Only the tweeters work. this is on a bmw x5 2002.
  • 1,284 Answers
Hi, it's quite obvious you have a bad amplifier...
Take care
Posted on Jul 22, 2010
  • redninjask Jul 22, 2010
    How can i test to make sure? and is there a fuse on the amp to replace in this case?
  • Shehu Pro
    Shehu Pro Jul 22, 2010
    yes there are fusein the amp which you have to test first and if they are good, then you need to call in a tech to check out the amp.
But radio now no speakers work only tweeters
That sounds more like an issue with the radio ground. Some radios ground through the antenna and finding loose connections can be time consuming. You can add an additional ground from the radio to a chassis ground. Poor connection at the Ground can cause strange issues like you are experiencing.
FYI, high-end stereos utilize an amp, or amps, for lows & mid-range speakers so the ground problem could be at the amp instead.
Jun 18, 2017 | Miscellaneous
Only tweeters are working while playing radio. No other speakers are working. ...radio operates normally, turn on , cd, all options work. What could this be? It's a 2006.
all speakers r connected to the same wires on the radio
If left/right balance and front/rear fader work properly
and sound is coming out it is likely (but not definite) radio is ok and speaker wiring is the issue.
HOWEVER, if it sounds the same on both left and right, it could be the radio. It is unlikely both sides have the same issue at the same time without it being in the radio.
The only way to verify it to disconnect the speaker and substitute a known good speaker.
So back to troubleshooting.
Dec 09, 2014 | Cars & Trucks
Foor radio speakers won't work but there is power to speaker
check connection and test speaker with multi meter
Dec 21, 2013 | 2001 Nissan Maxima
If all speakers except some of the super tweeters in my gem sound tr-150 cabinet aren't working, could it be the crossover network that they appear to be all wired to, is no good, or do you think all...
Did you actually mean "all speakers... AREN'T working" except some tweeters? Crossovers don't protect the woofers. If crossover die all speakers they protect go silent due to loss of signal. Excess volume or distortion kills speakers and not always linearly.
If you said it wrong and some tweeters work, I'd suspect the latter above...
You (or we) could guess or you could take out one tweeter at a time and swap it with a (presumed) working one or just emasure it for dead short or open with an ohmmeter. If the tweeters check out and work elsewhere the problem would likely be within the cabinet.
Sep 08, 2011 | Gem Sound TR-150 Speaker
The top part of the mackie speaker isnt working. all that is working is the big bottom part, and the sound sounds like the bass is the only thing coming out.
The typical cause of this is a blown tweeter or the tweeter has broken off of the horn and fallen inside the cabinet. Remove the screws from the horn and carefully remove the assembly. Try the speaker at low volumes to see if you hear any sound at all. Next, remove one of the wires and using a 9Volt battery quickly touch the 2 leads on the tweeter. If you don't hear a click, the tweeter needs to be replaced. Contact Mackie service for a replacement.
If you hear a click, then the problem is in the crossover or amp and further investigation willbe required.
Dan
Jun 05, 2011 | Mackie SRM-450 System
Tweeter has stopped working, speaker sounds like
Before you go buying parts you might not need why don't you swap components with the other speaker that matches it?
Apr 12, 2010 | Alesis M1-Active MkII Main / Stereo...
Blown tweeters on pair of The Amazing Alphas
check on radio shack maybe there got something that fits your necesities
Feb 06, 2010 | Audio Players & Recorders
When i connect the wires from my receiver to the top "red/white" connectors, the tweeter works fine, but the two midranges don't have any sound. When i connect the wires to the bottom connectors the...
are the two connectors on the speaker itself i belive you need two diiferent cables coming from the radio ect
what yu can do to make it work
connect the bottom connectos to the top connectors keeping the polatrity the same though
Jan 10, 2010 | Energry Speakers Energy Speakers Audissey...
Front speakers
either the wires in the boot where door folds open has broken wires in it or the most likely case you have 2 blown wolfers and 1 blown tweeter. common for cars with the monsoon stereo system, they made the radio better than the speakers.
Mar 09, 2009 | 2001 Volkswagen Beetle
Radio speakers shorting out
I suggest Checking the ground wire to the battery. It sounds like it is loosing earth ground to the speakers.or the technician didn't attach wire back to engine block near the compressor.
Jul 20, 2008 | 2005 Pontiac Aztek
Car Audio & Video Logo
69 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
