Question about Frigidaire Mid-Size Microwave
I'm trying to set my Frigidaire microwave clock and since I'm renting do not have an owner's manual. I've tried everything and it doesn't seem to work. Can it be that difficult?
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a frigidaire microwave and cannot find
You can locate the manual online here.
Posted on Aug 23, 2010
  • 234 Answers
SOURCE: we have a frigidaire microwave and in the middle
What you are saying the microwave stop work like heating,but but the clock counts down.If it is stop heating then there is a rest on or near the magtrogron.Once it cools down it start back heating.Open and close the door will reset power to the magtrogen{sorry about the spelling].Look for loose connector,or replace the click zon it should have a small red buttom on it.
Posted on Mar 18, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave turntable doesn't turn. Everything else
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can find links to helpful exploded view diagrams and part ordering help here.
But if you've recently had trouble with the cooktop lights, then the control board may be damaged.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Posted on Nov 29, 2009
tbirdfan1
  • 3051 Answers
SOURCE: My frigidaire GLMV169 manufactured in
Hello there:
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Posted on Nov 19, 2010
  • 125 Answers
SOURCE: Hi have microwave model #cfmv156dc, it will not
My suggestion is to test that the door switches are working properly. If the board can't see that the door is closed it will not allow the unit to start cooking for safety reasons. This is easily seen when you open the door of an operating microwave and it stops. This is a fairly common problem. I hope this helps. Good luck.
Posted on Apr 06, 2011
Is the clock that has stopped working fixable?
Yes, but ... If this truly is a failure, you're looking at replacing the clock/display/control board. This is usually a VERY expensive solution. In some cases more than it's worth as compared to replacing the entire microwave. The clock not 'sticking' is a rather unusual complaint. I'd highly recommend that you dig out the owner's manual - or check on-line for one if you can't find / don't have - to make sure you're not missing a step while setting the clock.
Jul 07, 2014 | Amana ACO1840A Microwave Oven
GE JVM1790WK convection microwave
I assume you've referred to your owner's manual to be sure you are operating the convection properly?
If for some reason you don't still have your owner's manual, you can get it here. See the tips on page page 30.
You can also do a hard reset by unplugging the oven for a couple of minutes, plugging it back in, then setting the clock and trying again.
If it's still not working, you may have a bad sensor or other problem.
Sep 04, 2012 | GE JE1590 Convection / Microwave Oven
Setting the clock on frigidaire micro wave
You can download Frigidaire owner's manuals and installation instructions here.
Dec 03, 2011 | Microwave Ovens
Setting the clock
Dec 03, 2011 | Frigidaire Microwave Ovens
I need directions on how to set the clock. Can't find the manual
Select "User Pref" upper right corner of keypad, then select from menu "Clock" (item 5), then enter time, select "Start" - you are have just set the clock for Frigidaire FGMV174KFB
Nov 07, 2010 | Frigidaire FGMV174K Microwave Oven
GE Spacemaker II clock not working (1994)
Are you working with the owner's manual?
You can download GE owner's manuals and installation instructions here.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
CLOCK
You should be able to go online to frigidaire.com and dowmload owners manual.
Jul 25, 2008 | Frigidaire Mid-Size Microwave
Setting clock on Amana Microwave Mod#FBG623T
It may possibly be locked, in which case holding the enter/start pad for over 3 seconds may unlock it.
Otherwise, you may want to call Maytag / Amana at:
1-800-688-9900 U.S.A
1-800-688-2002 Canada
Nov 04, 2007 | Bosch HMB402 Microwave Oven
Sharp R-9H56 Microwave convection oven
I have this model. Press clear then press Auto/Clock. Enter in the time eg 700 then press Auto/Clock again. The time should now be set
Jun 08, 2007 | Sharp R-1872 Convection/Microwave Oven
Frigidaire Mid-Size Microwave Logo
957 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
