Question about Dishwashers
Completely cleaned inside of dishwasher with soap vinegar and smells really bad
  • 6,784 Answers
HI. Mixing soap and vinegar will usually produce a foul order that will linger for sometime. It is best to use vinegar alone when cleaning out mold or calcium deposits. Never mix it will any type of soap. This will produce a toxic mix that is not to be inhaled.
With that said; the order will subside in about a week. You can accelerate the diminishing factor by running hot wash cycles with a cup of bleach for about two passes. this will accelerate the process of eliminating the order.
Posted on Jul 22, 2010
The soap pipe is not working
how about some more info. Does the soap pipe have a clog in it? Try putting a lenghth of wire down it to check for clogs. Also, run a load of full strength vinegar through the machine. Turn off the water supply, set the machine on to a point past the fill timer, then add at least 1 gallon of pickling vinegar, then turn on the machine. Stop it before it discharges and drains the vinegar, and reset it back to the beginning of the wash cycle. Do this several times until the wash water gets gunky, then let it complete the cycle after you have turned the water supply back on. Check the soap pipe now. Frankly, I have never heard of a soap pipe so I wonder if this is really your issue. do you perhaps mean a spray arm? At any rate, a good cleaning like this should solve your problem. BTW, if you do not want to use vinegar, try a package of lemon jello or a purchased product called Lemi-Shine both of which you run through your machine to clean it iout.
Mar 04, 2015 | Jackson JPX-300L Dishwasher
LG dishwasher LDS 5811 WW smells really bad has a slime film everywhere it was coated all over the upper arm and lower spray arm- dishes are not getting clean- and it smells so bad- any ideas?
it sounds like the problem is your water. go to www.dishwasherfilter.com and check out the dishwasher filtration system. it will solve your problem and works amazing. it is guaranteed or your money back.
May 14, 2013 | Dishwashers
Terrible smell inside the dishwasher. Bad drain smell
Hi
The smell usually comes when the unit is unable to drain water completely, you can run your dishwasher at its hottest temperature setting with 2 cups of vinegar inside the unit. After this take off the lower front panel and clean the drain pump assembly completely, also clean the drain hose, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 05, 2011 | Dishwashers
Dishwasher has a bad smell in it. I did find a teabag on the bottom of it and removed it. But even after many washings the smell is still there. The dishes are being cleaned. Any suggestions?
Use vinegar in it over night You will need enough so that you can acutally see it cover the gasket material in the bottom of the tub. After that... start cycle and drain out vinegar. Start a cycle like you were going to do a regular wash. Open the machine when your sure there is water in the bottom of the machine. Add 1/4 cup bleach and 1/4 cup powdered dishwashing soap directly into the water let it wash normally. If you still have the nasty smell after this... the next thing to do is to purchase a mold and mildew remover / cleaner like "Mr Muscle" and spray it all over EVERYTHING on the inside of the machine until the bottle is half gone. Let this sit for 15 minutes... then start a normal wash but do NOT add soap or rinse conditioner. Unit is now ready for regular washing. You may get spotted glasses on the first wash.... but it should not repeat.
This should get rid of the musty odor.
Thanks for choosing FixYa, Kelly
Jul 04, 2011 | Whirlpool Dishwashers
Cloudy film left on all dishes and glasses. How do I remove the film?
Buy a gallon of white vinegar and rewash your dishes this time add 1/4 of a gallon of vinegar in the water with no soap just vinegar and water.... Also check and see if the dishwasher is completely draining you may have another problem that the dishwasher is not completely draining and you are washing with dirty water...... check the screen in the bottom of the dishwasher and the spray arm to see if they are clean and open...... I have used vinegar in my dishwasher and it has taken the cloudy film off... You may have to add it a couple of more times if you have a real bad build up......
I also use cascade complete dishwashing soap and has helped the problem with the cloudy film.
Mar 28, 2011 | KitchenAid Dishwashers
I have really bad smells coming from the filter part at the bottom when i take it out and their is oalot of water coming from the filter end
A few tablespoons of vinegar in the middle (fabric softener) compartment of the soaps drawer every few loads should help with any smells.
You could add some diluted bleach to the soap and fabric softener compartments and wash something you don't mind getting bleached. It should kill off any mould or mildew that may have build up in the nooks and crannies. Open the button trap door and clean it out as well (front lower right corner - says push and has a large screw plug inside. Close really tightly after or it will leak)
Nov 06, 2010 | Haier HWD1000
SMELLS FUNNY, AND LEAVES RESIDUE ON DISHES
your dishwasher may just need a good cleaning. dump in two cups of cheap vinegar and run it on its hottest longest cycle, no soap, no dishes. When the cycle is complete the inside will be as clean as it can be and your funny smell and residue should be gone.
Aug 03, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Bad smell/silver tarnishes in every load/dishes not really clean
Working on it. Ran 2 heated cycles. One w light Clorox. One w vinegar. Last load had silver only very slightly yellowed. Thought it might be bacteria, so Clorox. OR residue of some kind. So vinegar.
Jan 16, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Removal of washing machine soap dispenser - Indesit
hi sue,
i've check the web and i found thatt you just have to pull the soap dispenser towards you. if some clips are rising when you pull it, gently press it down and continue pulling it.
tnx 4 using fixya,
drcool
Sep 13, 2008 | Washing Machines
Bad smell in my dishwasher
try running a load through witha shallow bowl filled with vinegar on the lower shelf, this should clean out anthing built up in it. does it drain into a garbage disposer hook-up? clean that out with vinager as well if you do
Feb 19, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
