Question about HP Pavilion Desktop, 3.06GHz Intel Pentium 4 519J (PS568AA)
Assert Failed - Appears Twice When I Boot Up. How Do I Get Rid Of It ?
  • HP Master
  • 4,806 Answers
Assert failed is caused by Wild Tangent game.
Wild Tangent makes a lot of little games that probably came
pre-installed on your computer. It usually has an updater (good to
disable that). Use the System Configuration Utility to see what is
starting with Windows and disable it - look for anything connected
with Wild Tangent.
Start>Run>msconfig [enter]
This brings up the System Configuration Utility. Look on the Startup
tab and find the probable culprit. Uncheck the box next to its name,
Apply and OK out.
Restart the PC and the error message should stop.
Alternatively you could go into the control panel and uninstall any game that's associated with Wild Tangent.
Regards.
Posted on Jul 22, 2010
Debug error
An "assertion" is a booby-trap inside a computer program.
Under normal conditions, the programmer has determined that his/her program will always find that the \'ASSERT\' statement is "true", e.g., \'ASSERT X > 0\'. However, in your case, somehow the value of \'X\' makes the statement to be "false". Then, the program "stops", due to something seriously being "wrong".
It\'s either some incorrect input data being fed to the program, or a "software-bug" inside the program.
Check your input.
Contact the author of the program.
Mar 13, 2014 | Microsoft XP Computers & Internet
Googleis my home page, but i cant get rid of inbox completely and it's interfering with-replacing it. what do i do to get rid of inbox completely? -
remove unwanted add-ons from control panel
  • Close all windows except for one Internet Explorer window.
  • Click Tools and then click Internet Options.
  • In the Internet Options dialog box, click the Advanced tab.
  • Click Reset.
  • In the warning box that appears, click Reset.
  • Click Close and then click OK twice. Restart Internet Explorer.
Feb 12, 2014 | Computers & Internet
Message Boot Lid open
Boot is the trunk, right? Find the switch in the trunk, maybe the wire fell off, or the switch has failed. Temporarily you might be able to either disconnect or ground the wire to turn the light off until you can get it fixed.
Mar 15, 2012 | 2005 Volvo S40
Box continually pops up saying ''Assert in LSP'' with three choices: RETRY, ABORT, OR IGNORE. IGNORE OR ABORT gets rid of it, but sometimes you have to hit it as many as 6 times. Gateway computer.
Try this
1.Reset IE and check plugins ->Internet Explorer - Reset
2.Delete browsing history: Tools > Delete Browsing History > Delete All
3. Try reset winsock:
run cmd.exe with administrative previlliges and type
netsh winsock reset
+restart
It could be also caused by some malwares...
Jul 22, 2010 | Gateway Computers & Internet
Assert in LSP original==reinterpret_cast (instance->org-startup-) Assertion failed capturelsp olspwsp_patches. cpp:202 How do I fixs this ?
An 'ASSERT' is a test, coded in some programming-languages,
e.g., the 'CPP' ("C-Plus-Plus") language, to say "if some-condition1 equals some-condition2 then continue to run this program", e.g., 'ASSERT X+Y = Z'.
If the logical-condition is false (e.g., X=1 and Y=2 and Z=99),
then you get an "assert-failure", and the program halts itself.
Now, why you get that condition, and what LSP (Layered Service Provider) has to due with apparently trying to install a security-patch downloaded from Microsoft, is another question.
Call Microsoft: 1-866-PC-SAFETY if you were installing a security-patch, and they, for free, will troubleshoot.
Nov 27, 2009 | Dell Dimension E510 PC Desktop
My tosiba a70-kl1 starts up with a black screen and error messages stating "PXE-E61: Media tes failure, check cable" and "PXE-M0F: Eiting PXE rom"
You haved enabled the capability for your computer to "boot" itself by reading from a boot-server connected to your network-cable.
But, the network-cable is unplugged, resulting in the "check cable" message.
What this _could_ mean is that the computer primarily tried, and failed, to boot from your disk-drive, and secondarily tried, and failed, to boot from your CD-ROM, and so it made a tertiary triy, which failed, to boot from the "network", i.e., that your hard-drive is not functioning.
Reboot, and enter "BIOS setup", and disable the "boot from network" option, to get rid of those error-messages. But, it's still possible that your disk-drive is malfunctioning.
Sep 14, 2009 | Toshiba Satellite A70 Notebook
Assert in LSP
The reinterpret_cast operator can be used for conversions such as char* to int*, or One_class* to Unrelated_class*, which are inherently unsafe.
The result of a reinterpret_cast cannot safely be used for anything other than being cast back to its original type. Other uses are, at best, nonportable
Visual Basic operand
Jun 22, 2009 | Dell Computers & Internet
M$ Internet Exploder 7 shuts down: Assert in LSP error popup
Your google desktop add-on is causing the problem. Try to start IE7 without add-ons. Right Click your IE7 Icon and start without add-ons, or go:
Start | All Programs | Accessories | System Tools | Internet
Explorer (No Add-ons)
Or type in this command at Start > Run
iexplore.exe -extoff
This will start IE7 without all the toolbars or add-ons that you can download or add to your Internet Explorer.
Go to Add/Remove Programs in Control Panel and uninstall the Google Toolbars/Desktop programs then try to start IE7 normally again.
Feb 18, 2009 | Computers & Internet
HP Pavilion Desktop, 3.06GHz Intel Pentium 4 519J (PS568AA) Logo
110 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
