The picture flutters on and lately has been staying off for several hours at a time.
  • 206 Answers
This is the lightbulb that keeps your tv powered up and does most of the projection on the screen so you need to replace it because soon if it is not changed you could lose you TV forever
hope i could help a little bit
Posted on Jul 22, 2010
Car flutters at an idle but does not die
My 96 Nissan maxima flutters when idling and also lights dim same time, it doesn't flutter when u first turn it on, but it eventually will
Nov 01, 2013 | 1994 Nissan Maxima
Radiator warning light flashed on and off several times on the way to work today. Tonight, did the same thing and then stayed on. I drove to an appointment several miles away. When I came back out...
if there is no noticable leaks might be head gasket. Check to see if a lot of vapour comming from exaust. You may have to get a pressure test on cooling system.
Oct 07, 2010 | 1999 Chevrolet Cavalier
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
Picture flutters and distorted
Capacitors going bad on your DM or FMT board. Very difficult to replace, but Mits does a rebuild on the chassis. I recommend talking to your Mits service center and getting the rebuild done.
Dec 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Won't stay on
Sanyo tech service helped.
Jun 17, 2008 | Sanyo DS32830H 32" TV
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
No picture
You have an intermittant vertical sweep circuit! It could be the vertical out put IC solder connections on the printed circuit board, or maybe the IC itself has poor connections between the IC and the contact legs that mount the IC, or another componet in the vertical sweep circuit. If you know how to solder and unsolder, work on printed circuit boards, then you shoul have no problem replacing the vertical sweep circuit. Good Luck
Oct 09, 2006 | Panasonic CT-25G6 25" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
