Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Brother Intellifax 4750e with black line (1-1/2" wide on right)
Only when making copies using fax machine....faxes received are fine?
  • 1 more comment
  • NayNay2 Apr 22, 2008
    Drum has been replaced.....cannot find any jammed paper....have opened and shot pressurized air in all available locations.
    I have changed the drum and toner units and still have problem. mirrors??? on upper area where drum/toner unit reside? where the glass is that I have cleaned several times or are they located somewhere else? Why only when I make a copy and not when a fax is printed? What does fax do differently making copy that would effect black line?
  • NayNay2 Apr 23, 2008
    Okay, I'm seeing the glass and mirror that I believe you are talking about (when I open the top cover). However, I am unable to remove the glass to access the mirror to clean it, any suggestions???
  • 101 Answers
The drum is scratch ,or there is a paper jammed .
Posted on Apr 22, 2008
  • Ping ong Apr 22, 2008
    Make sure you clean the charge wire which is located within the drum and toner unit. Sometimes if the charge wire is dirty it would cause that situation also check the mirrors if they are clean. Hop this will help you.
    Because there is a mirror that reflect the image to the drum, but went you faxing it doesn't use the mirror. You need to open the top cover remove the glass and look inside you will see the mirror.
We have a Brother intellifax 4750e. When we send a fax, there is a black streak down the right hand side of the paper. When we receive a fax, the streak is not there. The streak is about 1" wide. ...
Try cleaning the rollers with rubbing alcohol using a good quality paper towels, I find there is a buildup on the rollers causing streaking on the paper. If that fails the print head must be suspect.
Dec 30, 2010 | Brother Office Equipment & Supplies
When we send and receive faxes via our Brother Intellifax 4750e, there is a large black line on the right of the page.
hello, if this line is larger than 1 inch, and you already checked toner and drum, then the problem will be the actual scanner, this unit will need to be replaced,
Sep 29, 2010 | Office Equipment & Supplies
Receiving fax with a black wide (2") line from fax Brother Intellifax 4100
its the problem of your LED'S strip may be one of the LED is not working.It lights up green in color & its located under the top cover from where you send fax copy.
Please rate me if it was helpfull..
Aug 04, 2010 | Brother IntelliFAX 4100 Laser Fax
Faded strip down length of paper
CLEAN DRUM UNIT AS PER MANUAL . IF THAT DOSN''T WORK TRY REPLACING DRUM AND/OR TONER
Aug 26, 2009 | Brother Office Equipment & Supplies
Black line about 1 1/2 inches wide down side of faxes or copies
if your RECEIVED faxes look good, then leroyal is dead on. you will need a new CIS which stands for contact image sensor. if you have an authorized brother service center nearby, they may be able to do it for 100 to 150.00, depending on their pricing of course. if rec'd faxes are bad also, pull drum out and make sure the blue tab on top of drum is all the way to the right side, although that usually only leaves about a 1/2" black band.
hth,
razors
Jan 27, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother 4750e fax machine
1- check the small stip of glass and see if it has toner,
check the maintenance section of the manual (it's free, just register)
http://www.retrevo.com/support/Brother-4750-Fax-Machines-manual/id/19095ci557/t/2/
Aug 04, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
if the copy comes out black and/or sends black the Contact Image Sensor in the scanner may be needed.
Hope that helps...
Jun 17, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
When we copy on our 4750e fax it comes out with black page
Can you see light from the scanner unit with you make a copy or try to send out faxes? The bulb for the scanner may be burnt. You might be able to find a replacement bulb, search google or contact Brother.
Jun 16, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
1,188 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
