Question about Sewing Machines
Top thread looping bad don't know where tension knob is
  • 532 Answers
The tension knob is located near the front of the sewing machine. It has a dial numbered from 1 to 9. The larger the number, the tighter the tension.
Thanks.
Posted on Jul 22, 2010
What am I doing wrong when the stitching on top of the material is ok and straight and the backside is knotting?
wrong bobbin tension , but amazingly its actually easier to adjust the top threads tension to compensate for it , use your tension knob to slowly adjust , try an inch , slowly adjust try an inch , and so on to get a top and bottom thread tension to match , this will need to be adjusted for each major change in fabric (aka , knits to woven )
Aug 17, 2016 | Sewing Machines
How do I adjust tension on a Necchi Lydia 510 sewing machine?
loops under fabric means top tension needs to be tightened
try cleaning the top tension dial with some unwaxed dental floss and see if that helps. if it doesn't then the tension dial may need to be replaced
also check to make sure the spool of thread is not getting caught on the spool holder
also try a new needle--one that is correct for the fabric being sewed
Feb 10, 2015 | Necchi Sewing Machines
Singer 2263 loops on top of fabric
try changing the needle
thread the machine, use every thread guide
there could also be something wrong with the tension dial, it would
be a good idea to have the tension dial checked
Sep 23, 2012 | Singer Sewing Machines
I have a singer 7258 that I can not get the tension to loosen up on. The top stitch is straight across and adjusting dial doesn't help.
Hello
Adjust the tension
Load your sewing machine with one color on top, threaded through the needle. Load the second color thread into the bobbin and thread.
Fold the scrap fabric in half, and sew a straight stitch at least 2 inches long. Look closely at the seam. If you see loops of the bottom color thread on top of the fabric, proceed to Step 3. If you see loops of the top color thread on the bottom of the fabric, proceed to step 4.
Loosen the top tension. Since the top tension is so tight, it is pulling the bottom thread up through the fabric. Loosen the top tension by turning the numbered knob on the front of the sewing machine counterclockwise by one number.
Tighten the top tension. Since the top tension is too loose, the bottom thread is pulling the top thread down through the fabric. Tighten the top tension by turning the numbered knob on the front of the sewing machine clockwise by one number.
Sew a straight stitch 3 inches in length. Check the stitching. It is perfect if the threads meet in the middle, and you can only see the top thread on top and the bottom thread on bottom. If it still needs adjusting, go back to step 2 to repeat the needed steps.
Using two different colored threads makes it easier for you to see which thread is being pulled.
Always use proper precautions when working with electrical machines.
Aug 01, 2011 | Singer Sewing Machines
I need to adjust the bobbin/lower thread tension on my Freesia Viking sewing machine.... Now I know why it was sold. I sew lots... but am at a standstill on how to remove or get to it to adjust it..
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 08, 2011 | Husqvarna Freesia 415
I bought a White Family Rotary sewing machine made in 1909. While cleaning it up, I unscrewed part of the tension assembly on the face plate not knowing that these can be very difficult to get back...
  • Set up your sewing machine on a table with good lighting available. Plug in the electrical cord. Insert a new needle into the shaft on the needle bar and tighten the thumb screw to secure the needle. The needle bar is the area on the shaft where the assembly for the needle thumb screw is located.
  • Step 2 Thread your sewing machine according to the manufacturer's directions. This requires slipping the thread through various retaining and tensioning loops to allow for the proper drag while sewing. There is usually one loop at the top to go through first, then a second above the thread tension knob. Bring the thread into the tension knob area and pick up the loop of the tension wire. Bring the thread back to the next upper thread loop and then down to the needle bar where you thread the needle.
  • Step 3 Wind a bobbin with the thread that you intend to use. You may have to partially unthread your machine to do this. Make sure there is tension on the thread while you are winding it so that the thread winds properly. Insert the bobbin in the bobbin case and place it in the shuttle race then draw up the thread with the needle thread to prepare to sew. The shuttle race is located in the lower body of the machine under where the needle enters the throat plate.
  • Step 4 Cut a scrap of fabric from the fabric you intend to use for this project, at least 12 inches long and 4 inches wide. Double the thickness of your scrap by folding it in half lengthwise. Insert your scrap under the sewing foot and lower the foot into position. Sew a seam approximately 6 inches long then remove the scrap to check the stitches. If the stitches are loose on the bottom, adjust the tension knob to a higher number for more tension. This is done by turning the knob so that the indicator mark moves to a higher number. If the threads are loose on the top you will need to make the opposite maneuver.
  • Step 5 Sew more seams on your scrap, stopping to check your thread tension for your stitches until you have stitches on top and on bottom with no discernible looseness.
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Jun 17, 2010 | White Sewing Sewing Machines
    THREAD GET BUNCHED UP UNDERNEATH THE FABRIC, THE STICHES SEEM TO BE INCOMPLETE THE TOP LOOKS GOOD THAN I TURN IT OVER AND THE THEAD IS BUNCHED AND LONG LOOPS OF THREAD ARE LEFT. THANKS LOU
    Hi Lou! This sounds like a tension problem--the tension on the top thread is too loose. Try using different color threads on the top and bobbin, then carefully rethread everything. Stitch a couple of inches and check the underside. If the top stitches look fine and the bottom ones are loose and loopy, and with the pressure foot down, tighten the tension. Move the knob or dial (whichever you have) just a little bit. Sew a couple of inches more, and recheck. Continue to sew and recheck, gradually tightening the tension, until you see little if any bobbin thread on the top or top thread on the underside of the fabric.
    Let me know if this helps, ok?
    Robbie
    Jan 27, 2010 | Singer Sewing Machines
    Tension problems
    Hi, check that the thread tension knob makes only one rotation from 0 to 9 and stops at each ends, see that it moves in and out as you increase or decrease the tention, see that the small tension wire to the left of the knob is still in place, in any of these fail you need to replace/repair that assembly.
    Aug 11, 2009 | Singer 7462 Mechanical Sewing Machine
    March 12, 2009 kenmore 385.17922 sewing machine ***this site won't let me ask a question - because it doesn't have this sewing machine in it's PRODUCT LIST...but i'd still like to ask the questions, and...
    Dear VeeVeeV,
    when I've had that problem it was due to incorrect threading of the top thread. Sometimes it "jumps" out of one of the thread guides, particularly the round one with the tension spring. The bottom thread looping & the machine not sewing is my first clue sometimes that it's done that. good luck, Georgia
    Mar 12, 2009 | Singer 3116 Simple
    Sewing Machines Logo
    Top Sewing Machines Experts
    Tally Girl
    Tally Girl
    Marvin
    Marvin
    Are you a Sewing Machine Expert? Answer questions, earn points and help others
