Question about Poulan Pro 22" Self Propelled High Wheel Mower
I evidently put too much oil in the Proulan Pro Lawn Mower. Now I cannot get it started. It sputters at first but will not start. I have cleaned off the spark plug with a paper towel and sand papered the oil off the spark plug. But, I still cannot get the mower to start. This is the Poulan Pro Self-Propelled Lawn Mower (Model PR625Y22RKP)
  • 1 more comment
  • glennkrommin Jul 23, 2010
    I drained out the oil until I was down to the proper level. I sprayed WD-40 into the spark plug hole. I then replaced the air filter and spark plug. The lawn mover finally worked again. Thanks for the advice.
  • Anonymous Mar 15, 2014
    The engine won't start
    I cannot get the engine to start. I have recharged the battery and cleaned the spark plug, put in gasoline additive but still can't get it to start.
  • 279 Answers
First thing is to remove the excess oil. Take out as much as you need to to get to the line on the dipstick. Next, you may want to use a little WD-40 or similar cleaner to spray into the spark plug hole to thin the oil in there. Replace the spark plug and start the machine a number of times until it runs correctly. Using WD-40, remember the term "little". Good luck...Lee
Posted on Jul 22, 2010
Lawn mower ran out of oil and stopped running put new oil in and still not running is there something to do after putting oil in to make it run
If you can turn blade by hand first removing spark plug you then can try squirting 30w oil into plug hole and turn blade by hand. replace plug and try to start. Depending on whether you gouged the cylinder it may start.
Jul 06, 2014 | Poulan Pro 22inch 625 Series Briggs ...
Oil leaking from lawn mower muffler
Minds a 300 push mower and oil came out what to do
Apr 13, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
I have had my Poulan Lawn Mower for 4 years. The model number is 961320020. As I was mowing the lawn today, I thought that it might be running a bit sluggish and it dawned on me that I had not ever added...
Four years without adding or changing the oil?!
I think that was the problem right there.
Mowers need oil changes to protect the cylinder walls and valve guides every 25 hours of operation. Thats usually about one season if your yard is under an 1/3 of an acre.
Your mower ran on almost no oil for the last two years. The normal lawn mower only holds 20 ounces of oil. You topped off with 16 ounces! The four ounces still in the motor were probably so full of dirt and metal particles that it was grease! Which is no help to an engine that gets its lubrication by splash oiling.
Your mower should be oiled with 30 weight non detergent oil. Multi Vis oils are for engines with tighter machined tolerances. Your oil choice is going to go right past the piston rings and valve guides creating gobs of smoke! Go get some 30W ND oil at your parts store and put it in....but run the mower first so you can clean out all the gunk in the oil sump. Run it long enough for the oil to flow easily.
Once you put in the right oil you can run it and try to clear out the remaining multi vis oil.
If it keeps smoking...I would say you have permanent damage to the cylinder wall or valve guides.
Good luck and be careful!
Jun 24, 2010 | Poulan Pro " Pro" Self Propelled Mower
I have a Craftsman 650 series lawn mower. It starts but sputters and smokes and finally dies. I replaced the spark plug and checked the oil but it did not help. What do I need to do now??
I have a similar issue in that my Craftsman 650 in that it sputters and smokes out of the muffler and spits oil out from there as well. It does not die, but I cannot operate the lawn mower with all the smoke and oil blowing out. Plus, I get oil leakage on the deck of the lawn mower (top). What would I check for here?
Nov 17, 2009 | Craftsman Garden
Have a poulan motor had pre-mix oil in it.put
Remove and clean the jets in the carburetor
Jul 31, 2009 | Garden
My lawnmower won't start
Clean air filter and replace spark plug. If it is wet when you pull it out let it sit and dry out before putting new one in.
Jun 23, 2009 | Troy Bilt 5.5hp Self Propelled Mower
6.75 B and S push mower wont start.
Check the kill switch. It may be stuck in the off position.
Apr 26, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Poulan Pro 22" Self Propelled High Wheel Mower Logo
358 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
