Question about GE WBSR3140DW Top Load Washer
Stopped with full water
It stopped working in the middle of the wash cycle. What do I do?
  • GE Master
  • 8,220 Answers
Your lid switch may be bad. These fail mechanically and electrically.Stopped with full water - 7ac16b8.jpgTo get to the lid switch first remove the front panel so that you can get the top loose it is bolted down. Use a putty knife and do downward force to release the front panel spring clips.8e17656.jpgRemove the top and you will see the lid switch quick connect. Unplug that and sit the top down on a work bench or table. Check the switch for mechanical and electrical failure. Set your meter to ohms and close the lid. You should have continuity. GE TRAINING MANUAL
Posted on Jul 22, 2010
In the middle of a cycle, it has stopped and is
nf is NO fill
i would check your cold water line
take it off the machine and check the screen as well
no fill means it is timming out waiting for water
Oct 09, 2009 | Samsung WF337AA Front Load Washer
Amana nfw7200 washer stopped in middle of cycle and is flashing ''nd''
is it full of water? if so there is a drain problem and may have to clean out the pump
Aug 23, 2009 | Maytag NFW7200TW Front Load Washer
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Machine stopped in middle of wash cycle.
Timer needs replaced try gigling your timer knob and see if you get any reaction dont be afraid gigle it up and down hard sounds like point in timer are burnt
Sep 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washer stopped
Bear in mind I'M a novice.. but I'm going to try replacing the CONTROL PANEL ASM WJSE4150B1WW (for GE Model: WH42X10303 found one for $45 at partadvantage.com ... I don't have the water temp problem but the other two yes...
Dec 04, 2007 | GE WBSE3120B Top Load Washer
GE WBSR3140DW Top Load Washer Logo
187 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
