Question about Xerox WorkCentre M123 Copier
Trying to change paper size from A4 to 8.5x11 on a Xerox Workcentre M123
    President:
  • 2,072 Answers
  1. Pull out the paper tray.
  2. If necessary, slide the paper tray edge guides so that the guides are open.
    1. To adjust the side and rear guides, pinch the guide lever on each guide and slide the guides to their new position.
    2. To secure the guides in position, release the levers.
  3. Load the paper against the left-hand side of the paper tray. Paper can be loaded either short edge feed or long edge feed.
  4. If necessary, slide the paper edge guides so that they just touch the edge of the paper stack.
    NOTE: When loading standard size paper, set the edge guides onto the notches on the paper tray to match the paper size.
  5. Close the paper tray.
  6. Set the machine to detect the paper size automatically, or manually specify the required size.
    NOTE: Paper sizes detected by the machine vary depending on the Machine Administrator setting. See the Related Items below for additional information.
  7. If the type of paper has changed in the paper tray, then the paper type must be changed on the Control Panel as well. See the To modify the paper type on the Control Panel section below.
Normally just the guides need to be set correctly in the paper tray, The tray size sensing switched may be bad or the actuator on the tray may have slipped position.
Posted on Jul 23, 2010
How to solve mismatch paper size on xerox 4118
Set the paper size correctly.
http://www.fixya.com/support/t5246564-paper_size_mismatch_xerox_workcentre Paper size Mismatch on Xerox workcentre 4118 cant print
Mar 06, 2016 | Xerox Office Equipment & Supplies
Error C0...Xerox WorkCentre 5020DN Printer
C-0 declares that the size of the document you are trying to print is incorrect with the paper size you have in your machine's tray. To remove the error, press the red button on the control panel and check the size of the document within the printing properties. If the papre size of the document and the paper in the tray are correct then try to use another tray or bypass tray. If the problem still persists, call for service.
Dec 06, 2013 | Xerox WorkCentre C2424DN All-In-One Laser...
Download driver workcentre m128 for windows 7
Here you go:
http://www.support.xerox.com/support/workcentre-m123-m128/downloads/enus.html?operatingSystem=win7
May 16, 2011 | Office Equipment & Supplies
HI wat you can do is Most likely the tray setting has changed, Here is what to check. Press the [ Machine Status] button on the Control Panel..
Jan 10, 2011 | Xerox WorkCentre 4118 Network Kit...
When trying to print from computers the message comes up paper size mismatch Xerox M20i
double check the paper setting and margins set up on your computer.
check the printer properties
Mar 23, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox 423 DADF seting
what do you mean dadf seting
you choose the dadf from the front screen
Dec 11, 2008 | Xerox WorkCentre M123 Copier
Getting a black line on the coppied paper
If you lift up or open the auto feed you should gain access to a small sliver of glass underneath the autofeeder. Clean that glass with alcohol or some other glass cleaner. That should clear this up.
If any debris get on that glass the result is dark lines caused when the page travels over that part of the glass. Hope this helps. Let me know.
Nov 25, 2008 | Xerox WorkCentre M123 Copier
Xerox workcentre xd105f
It is entirely possible you have a small piece of paper that got ripped off somehow and it is now blocking the sensor leading the machine to think it has a paper jam.
Follow your jam clearance instructions again and pay close attention and rotate all movable parts in the jam area many times, then reboot the machine multiple times and allow the machine to completely come up before rebooting again, it may be necessary to reboot the machine 3 or 4 times to clear this error, each time following the jam clearance, if this doesn't resolve then you should have an expert take a look at the machine.
Oct 19, 2008 | Xerox WorkCentre M123 Copier
Xerox WorkCentre M123 Copier Logo
553 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
