We have WS5080 washer and the water does not drain have checked and clean the drain way had A pressure cylinder sub assembly fitted some months ago can any one advise whats wrong as I Have no truct on miele call out engineer as he has charged three time and still the same problem we are a small nusring home in sutton surrey area.
Have you solved your problem regarding your Miele washing machine? if so, what you did ?
Thanks for your answer.
Fahim.
Posted on Dec 26, 2010
My name is Brenda. I got my washer about 2 months ago. The washer does not fill up with enough water to get all the cloths wet,therefore there is no way they can get clean.
hi Brenda.
if you only got your washer 2 months ago i would not mess around with it,i would get in touch with whom ever you bought it of and get them to check it out.
Dec 17, 2017 | Washing Machines
Whirlpool duet 8E error code, what is the cause?
F8E0Steam valve failureCheck the water supply hoses for kinks. Check for a restricted screen in the water valves. Replace the steam valve if defective.
Steam valve
F8E1No water detectedMake sure that both water supply valves behind the washer are fully open. In winter, check the fill lines for freezing. Check the drain system for a siphon problem. If the water valve assembly is defective, replace it.
See the repair guide to fix it yourselfWater valve assembly
F8E2Dispenser failureThe dispenser can't move into position. Unplug the washer and check the mechanical linkage on the dispenser housing. Repair or replace any damaged dispenser parts.
Dispenser assembly parts
F8E3Overflow conditionUnplug the washer and, if the washer is overfilled, check the water valve assembly for proper shut-off of water flow. If the water valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water level pressure switch.
See the repair guide to fix it yourselfWater valve assembly, water level pressure switch
F8E4Low water flowThe flow meter detects a long fill time. Make sure that both water supply valves behind the washer are fully open. In winter, check the fill lines for freezing. Check the drain system for a siphon problem. If the water valve assembly is defective, replace it. If water flows normally, replace the flow meter.
See the repair guide to fix it yourselfWater valve assembly, flow meter
F9E1Long drainRemove excess suds; the washer can't drain excessively sudsy water. Check your house drain system for a clog. Check the drain hose for kinks or clogs. Replace the drain pump if defective. If the washer drains properly, replace the water level pressure switch because it isn't accurately detecting the water level.
See the repair guide to fix it yourselfDrain pump, water level pressure switch
Oct 16, 2016 | Whirlpool Washing Machines
My indesit iwc6105 washing machine is not draining at all.
see this causes: and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out
Oct 11, 2012 | Washing Machines
My washer has just started to leave about an inch of water in the bottom of the tub after the cycle is complete, leaving my clothes soaking wet. How do I get the water out?
Hi.
The problem is either caused by a drain system fault or by a defective pressure switch.
Check that height and setting of drain hose at the back are correct. If the hose is not set correctly (check manual), then water will flow back inside the appliance. The problem is called siphoning.
Make sure there is no drain system blockage. Inefficient drain because of blockage results in soaked water. Check hose connected to pump located at the base of the washer.
Check and eventually replace the pressure switch. The pressure switch detects water level and determines when to stop the spin part of the cycle. The pressure switch is located in control assembly, near to control module. Clean the long rubber hose connected to the switch.
Inside the control assembly look also for an envelope containing the tech sheet. The document will contain the instructions to run diagnostic cycle in this model. Run a diagnostic cycle.
Regards.
Ginko
Aug 29, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
I have a Maytag Bravo Washing machine, and am having trouble with the drain cycle. I have replaced the pump twice and have checked the drain line. My washer will start and get to the drain cycle and it...
Here are some pointers to look at to determine the real problem. The code Ld indicates that the water level does not change after the drain pump is turned on.The machine/motor control detects such condition through the water level pressure sensor located in the control itself.
Since the drain pump is definitely not the problem, either the drain hose is blocked or installed too high, or the pressure sensor system is malfunctioning. Check if water is actually draining or not. If yes and the tub is actually empty when code appears, then the problem is in pressure sensor system. If no, then check for drain blockage.
Unplug the machine. Remove the three screws from the rear of the console assembly then pull console towards the front of washer to hinge it open and remove console. The machine/motor control assembly is located on the right hand side of the machine that is enclosed in a casing with a clear tube/hose connected to it.
The clear tube/hose is the pressure hose. Check to make sure that everything connected to the machine/motor control assembly is properly attached and fully inserted and the pressure hose has no air leak, kinks, or moisture.
Turn off the water supply to the washer and disconnect the hot and cold water hoses from the rear of the washer then remove the end of the drain hose from where it is installed. Remove the eight screws from the rear panel and remove the panel.
Inspect the pressure hose for evidence of water then replace the hose if water or moisture is present. Inspect the air dome hose connection port for lint or flashing.
Use a small round device such as a small screwdriver to ensure that there is nothing blocking the air dome outlet on the tub. Also disconnect the pressure hose from the machine/motor control and blow air forcefully down the hose and also into the pressure sensor inlet in the control.
Replace the machine/motor control assembly if and only if verified that there are no issues with the pressure sensor system. Remove all the wire connections to the machine/motor control then remove the screw holding it to the console tray. Two plastic legs on the rear of the machine/motor control assembly are fitted into the console tray. Lift the front of the control assembly to pivot it out from the console tray. Reinstall the new machine/motor control assembly then secure it to the console tray and reconnect the wire harnesses.
NOTE: It is a good idea to take note of the wire harness connections before disconnecting them to prevent messing them up upon reconnection.
Labeling the connections makes reconnection more easily and trouble-free.
Jul 15, 2011 | Maytag Washing Machines
The water is not fully draining from the wash cycle. flashing F1,F21, 5D, please advise. Washer was purchased two years ago. thanks
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Possible causes/proceedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
Sud: Suds lock (overdose of detergent detected during wash cycle)
The motor control unit senses a suds lock condition by analyzing the
current draw on the drive motor. If "Sud" is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
excessive detergent, or excessive suds.
¦ If too much detergent was used:
-Run the unit through a Rinse/Spin cycle.
-Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
First remove the bottom panel and grab yer tech sheet. It gives the faluts and directions to diagnose or correct as shown above. Clear the pump filter.
Watch this video that shows how from my main man Double H
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore 80 series about 4 years old and it is leaking. Had a repair man over 3 months ago and it did not leak. However, I see my baseboard behind the washer pulling away and ran a small load...
check to make sure the drain hose is all the way in the drain pipe in your wall. there should be a strap, or tie wrap holding it in place to keep the water pressure from pushing the pipe out of the drain during the drain cycle. if not, the water pressure will cause the drain hose to rise up and allow water to leak down the wall. use a flashlight. you should be able to see a trail of water residue leaking down the wall. slide the washer out a bit and run it. see if the water is coming from the wall, or leaking out of the washer itself. let me know and we can go from there.
Nov 20, 2010 | Kenmore 24902 Top Load Washer
My pressure washer will start, but when I pull the trigger it dies.
hi , first thing to do is a full service on it , clean the air filter , clean the spark plug, check the oil , clean the inline guaze filter on the water inlet side , open the small screw on the bottom of the carb bowl and drain out any water that may be in it , then try it with a water supply but without a hose and lance connected , this will let you know the engine and pump are working , some washers are fitted with a small piston/cylinder comming from the pump with a linkage leading to the carb this may be sticking/jammed , if you post more details we should be able to help
Mar 07, 2010 | Honda Pressure Washer PSI 3000
Maytag neptune front load washing machine will not fully discharge water after the rinse cycle...HELP???
Check the drain hose and clear it from any debris that might be blocking the water from draining out completely. If the drain hose is clear of debris, check and clean the pump. Disconnect the machine from the power outlet before servicing for safety purposes.
Remove the rear access panel to access the pump and disconnect the wiring harness from the terminals of the drain pump and the pressure switch.
Loosen the clamps holding the drain hose and the tub hose to the pump assembly. It is a good idea to spread a towel under the pump before loosening the clamps.
Remove the hoses and rotate the pump assembly counterclockwise to release the pump assembly support legs from the keyed slot in the base of the washer. Remove the pump assembly from the washer.
Clear the pump impeller from any debris that might be causing it to work improperly. Clean the tub and the drain hose.
Reassemble the pump, the hoses, and reconnect the wires to the terminals of the pressure switch and the drain pump. Reinstall the rear access panel and run the machine.
Replace the pump (part #25001052) if water still do not drain out completely.
Remove the plastic bag covering the pressure switch. Press in the locking tabs on the back of the pressure switch and pivot the pressure switch off the pump bracket.
Grasp the pressure switch and lift the nipple of the pressure switch from the pump cap.
Install the pressure switch into the new pump assembly in reverse of the steps above.
Feb 24, 2010 | Maytag Neptune MAH6500A Front Load Washer
I got the pressure washer started - lots of smoke etc after not having used 3 years. I then poured in wrong oil to top it off - my brother's chain saw bar oil. DARN. After 3-4 minutes it started rattling...
nope! you have blown the seals and most likely the cylinder is full of water. You will need to take it to the repairer to have it cleaned checked and new seals fitted. $200
Jul 31, 2009 | Karcher 1750 psi Electric Pressure Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
