Question about John Deere Garden
My lt150 lawn tractor is backfiring when the pto is engaged and cuts off in about a min of use, but it runs fine without the pto on.We have drained the gas and put in new gas, and cleaned out the carborator. what could cause this problem?
    President:
  • 1,851 Answers
Sounds like the float is bad - what happens is the float sits just a little off and when you add the demand of more fuel it skewers the RPM by starving the engine.
Try removing the carburator and either adjusting the float by bending the tab or replace it. As part of this repair i suggest you just replace the needle and seat as well if they are over a year old.
Thanks,
Gary @ Fix Ya
Posted on Jul 22, 2010
    New Friend:
  • 4 Answers
Sounds to me that your pto clutch has a wire rubbing , usually it is shorted close to the clutch
Posted on Apr 17, 2013
I have a newer John Deere LT150 that runs fine at times and then seems to flood while you are mowing. If you pull the fuel line off of the filter and drain the gas it will start and run till it runs out of fuel. When you hook up the fuel line again it seems to run ok for a while, but will eventually flood again. Any ideas? I've changed the filter, and coil already. No luck.
Posted on Jul 20, 2011
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Model LT150. Why won't blades engage?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
JOHN DEERE LT150 LT160 LT170 LT180 LAWN GARDEN TRACTOR Service Repair...
Oct 20, 2015 | John Deere Garden
Where is the safety switch to engage the blade
Your lawn tractor will have a lever that raises and lowers the mower deck which houses the two cutting blades. By lowering your mower deck to the desired cutting height, the blades should automatically engage. By raising the deck back to it's highest position, the blades will automatically disengage. Should be simple enough. You can consult your mower manual. If you don't have one, you can easily find it online using the make, model and year of the lawn tractor.
Jul 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My 16 hp b&s simplicity lawn tractor disengages the PTO while cutting the lawn on it's own. Is this alternator issue??
could be either
the voltage regulator will have to be checked for correct out put to run the PTO
It could also be a problem PTO unit that is drawing more current than the alternator can put out
have the system checked out by an accredited mower shop that has an electrician with experience
Jan 08, 2018 | Garden
Blowing fuses
try unplugging the pto, starting the mower and then engaging the blades. If it still blows a fuse the problem lies in the mowers wiring. If not the problem is the pto. Hope this helps
Jul 13, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
When cutting with pto on and going into reverse and forward again the pto cuts off
That is a safety feature. When the blades are engaged and you go into reverse, they will shut off until you get out of reverse and turn the blades on again.
Jun 18, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
487 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
