Question about Samsung CLP 315 Laser Printer
Hi my samsung clp 310 printer regularly jams paper halfway to completion. ....
    Guru:
  • 366 Answers
Hi
Please look at the printer properties under Paper, you will see that the type of paper used can be chosen.
1. This apparently makes the printer behave differently when the default is not chosen.
For example, when I choose Thick Paper, the printer feeds the paper inside the printer much slower than when default is chosen. This, most likely, is done to prevent the paper from jamming up somewhere inside from feeding too quickly.
Therefore, if one is finding that their printer is constantly having a paper jam, changing the paper type may have positive results.
2. Heat maybe another source of paper jams. Although there is no paper jammed in the laser printer, the laser printer may stop printing due from overheating. Therefore, if heat is the culprit, changing the paper type may not work.
Hope this helps !
Posted on Jul 23, 2010
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 57 Answers
Exit sensor. Go to Youtube and watch this video: 5fJHykzkfww
Then go to ebay and get one for $8 to $12. The video shows you how to fix the printer in about 15 minutes.
Posted on Apr 26, 2015
  • 3 Answers
I have a CLP-300 (don't know how similar it is but...) The paper jams alot also - I have found that cleaning the area around the imaging unit seems to help.
but usually the best fix is to replace the Waste Toner Bottle. that seems to let it work for awhile. If it starts acting up again, I'll empty the bottle, vacuum the imaging unit area and seems to help. I think 3 times is the most I have been able to do this before needing to use a new toner bottle.
Hopefully this helps...
Posted on Aug 28, 2010
3 Suggested Answers
jyvibar
  • 148 Answers
SOURCE: samsung clp 310 printer regularly jams
avoid using paper that is below 50 gsm
Posted on Mar 26, 2010
  • 113 Answers
if your printing is halfway to the exit. it is most likely the exit sensor is mulfunction.
get the exit sensor replace.
Posted on May 21, 2010
Paper jams on CLP-310 series printer about halfway through the page
Hi
The printer driver is corrupted and need to reinstall and install the printer driver and again set up the printer again.
I am sure it will helps you solve your problem. But if not, let me know if you need more help.
regards
Mar 03, 2011 | Samsung CLP-310 Series
I have a Samsung CLP-310 and I've mislaid the units manual. On the top of the unit down on the bottom right hand corner there are four (4) colour icons a yellow, red, blue and a grey, all which light up...
Here is the link to the manual, it says that the flashing light is PROBABLY caused by lack of toner and the first step is to replace/replenish the corresponding flashing light to the toner. It explains that when the light turns stys on all the time the toner will be empty.
With regards to the paper jamming, there is 3 pages on things to do or try.
I hope this gives you a few ideas
http://www.samsung.com/uk/function/search/espsearchResult.do?keywords=Samsung+CLP-310&input_keyword=Samsung+CLP-310
Nov 30, 2010 | Samsung CLP 300 Laser Printer
CLP-310. paper jammed and it can't be removed. Can the roller be removed to get the paper out? that's the only way the jammed paper is going to come out.
I would recommend that you take it to a authorized printer repair shop and have them remove the paper. Printers have sensors that if not properly installed upon servicing the machine it will give error codes and stop the unit from printing.
When I have paper jams on my printers I always pull the paper from the discharge side to prvent any sensors being bent or broken. Good Luck!!!
Sep 21, 2010 | Samsung CLP 315 Laser Printer
My Samsung CLP 310 Printer keeps on jamming halfway through printing.
Hi There is a sensor next to the fuser unit in the top rear left of the machine. It fails due to the fuser heat and causes this fault. It must be replaced, no choice. Good luck.
Sep 21, 2010 | Office Equipment & Supplies
My Samsung CLP 310 is having paper jam issue; it prints half and then gets jammed halfway; opening and closing the front panel sends the paper out but upper half of the paper prints ok but lower half shows...
You'll probably have to replace that exit sensor. Cleaning might not do it. Go to YouTube and watch this video: 5fJHykzkfww
You can get the part on eBay for about $10 and it's a fairly simple 15 minute fix.
Sep 02, 2010 | Office Equipment & Supplies
My samsung printer clp 315 has a paper jam with about 1/3 of the paper out the exit everytime
From You Tube:
http://www.youtube.com/watch?v=5fJHykzkfww
DIY video tutorial on how to repair the Samsung CLP-315, CLP-301 laser printer "paper jam" problem, where the paper stops printing about halfway through for no apparent reason. My printer worked great otherwise, but was out of warranty. It would have been less expensive to get a new printer.
The problem is a very cheap sensor.
This repair takes 15 minutes and is inexpensive. Read the comments below.
I got the part from SamsungParts.com. Search for part #0604-001393
Jun 16, 2010 | Samsung CLP-315W Laser Color Printer
Samsung clp 310 printer regularly jams
May 14, 2010 | Samsung CLP 315 Laser Printer
Printer stops hafway the print, giving paper jam. once paper is removed it still gives 'paper jam' , once turned off ad on is disappers but next print is still jammed halfway
Yes, bad exit sensor. Go to YouTube and watch this video: 5fJHykzkfww
Apr 11, 2010 | Samsung CLP 315 Laser Printer
My Samsung 310 printer is giving a paper jam message inside warning when I turn the printer on and yet there is no paper jammed inside. Cannot print. Been working fine before. Mayb 100-150 pages printed...
Chek paper size (A4, letter...etc)in driver options and compare it whit your file settings (fo example - you trying to print something whit paper size A4 but printer expect letter format...etc)
Clean paper feed roller
Apr 08, 2010 | Samsung CLP 315 Laser Printer
I will try to add the video to this post. The sensor is available on eBay for around $8 to $12 and it takes only about 15 minutes to fix the printer.
Mar 26, 2010 | Samsung CLP 315 Laser Printer
Samsung CLP 315 Laser Printer Logo
1,468 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
