Question about HP Pavilion dv9700t Notebook PC
My laptop wont turn on. i also doesn't blink 3 times when i press the power button with the ac adapter plugged in. i tried taking off the battery and holding the power button on for 1 minute but that still doesn't work. is there any way to fix this?
    Sniper:
  • 51 Answers
Does the blue light come on at the side where you plug your ac adaptor in? If it does, and your laptop still wont turn on, its likely you have a motherboard failure. Also try this without the battery inside. If the light is not coming on the charger port at the side, then its most definitely your ac adaptor at fault.
Posted on Jul 22, 2010
Wont start up
Remove the battery and AC Adapter cord, and press and hold the power button for 30 seconds. Then, without replacing the battery try plugging in your AC Adapter to see if you get any love. If that doesn't work, remove the AC adapter, reset the board again, and this time hold the power button down as you plug in the AC Adapter cord. If you still don't get any lights, you could try removing your memory, reset the board, replace the memory, plug in the AC Adapter, and try one more time.
If all of this fails...you should take advice from experts,call at-http://www.vtechsquad.com
Sep 05, 2012 | Acer Aspire 7750G-6662 - Core i5 2.4 GHz -...
My mini 10 was working fine last night. I shut it down and pligged it in over night and now it will not power up.
Try this.
remove the battery, unplug the ac adapter.
press and hold the power button for 60 seconds
put the battery back, plug in the ac adapter
turn on the system
hope it works
Apr 18, 2011 | Dell Inspiron Mini 10 Notebook
Wont turn on and wont charge plug light is blinking
Power darin the computer
1. remove the battery
2. remove the AC Adapter
3. press and hold the power button for 1 minute
4. once done plugged back in the battery and adapter
5. turn on the computer
6. if it does not work call the tech support for possible mechanical failure.
Hope it helps.
May 12, 2010 | Toshiba Satellite A20-S259 Notebook
Wont turn on. will blink 3 times
These laptops came with a lot of motherboard issues. I suggest you try a manual reset. Please remove battery and AC Adapter and hold down power button for 30 sec. and then put battery back in and AC adapter and try starting.
Feb 06, 2010 | HP Compaq Presario V2000 Notebook
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
My inspiron 1520 will not turn on. the power light will stay lit, and the capslock will blink like 45 times, and the nothing happens
Remove the battery as well as the adapter. Then plug back the power adapter only. Try to boot up with out the battery. If it worked your laptop crashed from hibernation or stand by. If not, BIOS might be affected and needs reset.
Hope this helps.
Oct 01, 2009 | Computers & Internet
Laptop wont boot and the battery and power lights flash
a simple power cycle might work. Take out the battery but keep the ac power connected. hold the poewr button down for 1 minute. then hit the power button again and it should poewr back up. If this doesn' t work. iyou said hte battery light flashes so the problem isnt the battery..the problem might be hte ac power adapter..if you have a warranty this would be a good time to call them. Try the power cycle first though this fixes the problems lots of the time
Apr 15, 2009 | HP Pavilion dv1000 Notebook
Wont power-up with AC adapters, with or without Battery!
the notebook cannot be charged without the charger and further more if it is not working properly ,try get a new one and it will work.i also recommend that you show it to a technician .
Dec 24, 2008 | MSI MS-1022 Notebook
Problem with laptop- no power
The battery needs to be taken out once in a while. It is possible to use the ac adapter and power cord without the battery to power your laptop. Please press on the power button for 10 seconds for your computer to turn on. Check if you can see any message on the screen.
Sep 04, 2008 | Toshiba Satellite A105 Notebook
Power will not turn on??
Try this:
1. unplugging the power cable
2. removing the battery
3. plug in power cable
4. switch on and start up
If this works, shut down, unplug and replace the battery.
Hopefully your problem is resolved.
John (Computer Tuition, Blackpool)
Nov 08, 2007 | Compaq Presario 900 /1500 Series EVO...
Open Questions:
HP Pavilion dv9700t Notebook PC Logo
254 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
