Question about Samsung HP-S5033 50 in. HD-Ready Plasma Television
I have a samsung HP-S5033. I have sound but no picture.
  • Samsung Master
  • 11,800 Answers
If this happens whatever the source of the image then the problem is hardware (an electronic part has failed) , not software (a bad setting). To fix that you must dismantle the tv and start testing components, starting with the high tension module and its power line, followed by the power source. This requires a good experience in electronics, otherwise you can do way more damage and hurt yourself - the voltage in the high tension line is around 250Volts , more than enough to kill you. If you don't have this experience then it's better to call a repair man. Your problem doesn't appear to be very complicated so it might cost you less than $200.
Posted on Jul 22, 2010
  • Bryson Williams Jul 23, 2010
    I do have an electronics background and am use to dealing with high voltage. I repair x-ray equipment. I would to know what specific boards I should be testing. Which test points? What voltages? I already checked for bulging caps.
  • Azrael SRL Jul 23, 2010
    Here you can find the service manual, buy it and follow it.
    http://www.tradebit.com/filedetail.php/3...
How do I fiix vertical lines on the left side of my samsung plasma tv?
There are many reasons for the fault. The most common fault found is with the loose connection of the COF. It will be best to contact the authorized service center for Samsung in this case.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Pictures of faulty plasma screen are given by one among the posts in that site.
Jul 30, 2014 | Samsung HP-S5033 50 in. HD-Ready Plasma...
What are the solution of no sound from the speaker?
Check the speakers for any defect is the first step. If it is found OK, check and replace damaged component/s at the audio output circuit section. If you wish to get some more, check the site linked here.http://electronicshelponline.blogspot.com
Aug 04, 2013 | Samsung HP-S5033 50 in. HD-Ready Plasma...
Need a flow chart or schematic for samsung hp-s5033 we change three pannels set still wont power on.
WHEN YOU SAY SUSTAIN BOARD YOU MEAN Y BORD AND WHEN YOU SAY BALLAST BOARD YOU MEAN UPPER Y BUFFER BOARD ONE RULE WHEN THE Y BOARD OR Y BUFFER BOARD ARE DEFECTIVE YOU MUST REPLACE THEM AT THE SAME TIME AS A SET ,A NOTHER POSSIBILTY BUT VERY RARE X BOARD COULD BE SHORT OR WORST OF ALL THE PANEL BUT 90 PERCENY OF THE TIME WHEN YOU REPLACE THE Y BORD WITH THE 2 BUFFER BOARDS YOU SOLVE THE PROBLEM HPOE THIS WILL HELP
Jul 30, 2010 | Samsung HP-S5033 50 in. HD-Ready Plasma...
SAMSUNG HP-5033 VOLUME GOES TO MAXIMUM WHEN TURNED ON AFTER BEING SHUT OFF
One possible cause.
The Function Buttons on the TV have shorted,particularly the Volume button. The part is a PCB (Printed Circuit Board) and needs to be replaced.
Apr 11, 2010 | Samsung HP-S5033 50 in. HD-Ready Plasma...
There is need of Samsun pcsuit compatible with window7.
search on google new version of samsung pc suit available
Apr 07, 2010 | Samsung HP-S5033 50 in. HD-Ready Plasma...
Tv dosent have any video it only has audio no
you have bad capacitor in circuit board.
www.youtube.com search for , plasma tv capacitor repair. video's on how to tell a bad capacitor and also how to replace one will pop up . 15 to 35 dollar fix with a sodering iron and some soder ( and capacitors) you will be watching nfl in no time
Feb 26, 2010 | Samsung HP-S5033 50 in. HD-Ready Plasma...
No HD picture on HD TV
Yes, you need to buy HD station.
But with DVD you can get HD quality without any other station.
Feb 03, 2009 | Samsung HP-S5033 50 in. HD-Ready Plasma...
Image is grainy whenever tv is cold
try having the v_set and v_scan voltages reset 15vdc lower..
Nov 02, 2007 | Samsung HP-S5053 Television
Samsung HP-S5033 50 in. HD-Ready Plasma Television Logo
285 people viewed this question
Jerry Greenberg
Jerry Greenberg
