Question about Garden
Need to know how to put the spring back in for pull start stihl trimmer can you help
  • groomsy77 Jul 23, 2010
    Very helpful thank you
    Brigadier General:
  • 3,917 Answers
Hi
Please check the bellow link for the video and the detailed transcript at the bttom for your query…
http://www.ehow.com/video_2328977_how-install-lawn-mower-starter.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 23, 2010
Stihl RS 55 R trimmer
remove the recoil section from the unit and there should be a black plastic finger pivoted in the pull section
that throws out or is moved out and locks into the pulley housing
this is the lock/clutch that makes the recoil engage
check that it is not broken off , is in correctly ( part available from stihl or ant mower shop)
Aug 09, 2016 | Stihl Garden
How to start a Stihyl gas trimmer?
here are the steps to starting most stihl trimmers:
#1 turn the choke on (should be a little black knob or an orange switch on the engine itself)
#2 press the primer bulb 3-4 times (should be a little plastic/rubber bubble again on the engine)
#3 put trimmer on ground or bench (I find ground works best)
#4 pull the pull cord fast and hard away from the engine
#5 once it starts turn the choke back off
Jul 20, 2014 | Stihl Owners Instruction Manual Gas Edger...
Stihl trimmer FS85 broken pull start rope can this be replaced easily?
Somewhat, but if you have NEVER done one successfully before, and have been show basically how to do it, including the most common knot to use and how to tie it, you should really find someone who knows for sure how to repair it before attempting it yourself and firing the recoil spring into your eyes or something.
Aug 13, 2013 | Stihl Fs80 Line Trimmer Hardware
STIHL WEED TRIMMER
With the plug removed the starter should pull very easily. When trying start did the cutter head try to spin? If yes clutch springs may need replacement
Jul 24, 2013 | Garden
The starter cord jammed on recoiling, after attempting got release it the recoil spring rewound, now the cord and spring are interlocked. I'm looking to strip the recoil mechanism but I believe I
Its an easy opperation to undertake if you know how. Take note of where everything goes during the stripping down of the recoil assembly. Use eye protection when trying to recoil the rewind spring, they have a tendency to jump back out at you while coiling them back in. easiest way is to start by putting the hooked end into the plastic housing and work your way inwards coiling it back in. Then place the starter cord roller in on top, adding the one or two black sliders, the washer and the spring clip to hold it all in place.
Feb 16, 2013 | Stihl Trimmer Oe Rewind Starter Spring 36...
One day when i went to start up my stihl weed eater it wouldnt pull so i took the plastic peice off and ther is a spring maybe or something right next to the pull cord and it was not on anything i pulled...
first off what model of trimmer is it? an fs what? second, if you are talking about the recoil spring you will need to go to a STIHL dealer and order a new one. If it came off one end then that means it broke and needs to be replaced and if it isn't broken but now uncoiled replacing it will be easier then trying to rewind it and put it back together
Jan 16, 2013 | Garden
Schematic diagram to repair a STIHL FS 45 trimmer
hello, need a operators,parts manual for a stihl,echo chainsaw,hedge trimmer,line trimmer,edger,pole saws,concrete saw, as far as i know thay don't post any of these on line for the consumer,if i had a dealer number than i would be able to provide you with one,these manuals are available through the dealer only,hope this helps.``
Jan 11, 2012 | Garden
I just replaced the recoil \\starter rope on my blower
Are you sure you have the right length rope??? If you are sure the rope length is correct you may have wound the recoil spring too tight causing it to run out of travel. You want the recoil spring just tight enough to pull the rope all the way in.
Wayne
Feb 26, 2010 | Oregon Scientific Complete Carburetor for...
Pull cord is out and wont return. unable to crank stilh fs 45 we
Could be several things including a broken return spring. If you are not experienced with these springs please take it to a reputable shop to avoid any personal injury.
Jun 09, 2009 | Garden
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
