Question about Teac CD-RW880 CD Player / Recorder
DIN UNLOCK on the display
When I hit the record button, it flashes WAITING for a few seconds then goes back to BLANK DISK.
  • 3,083 Answers
The CD isn't reading the disk, so it reports "blank disk". It could be as simple as the CD laser lens having dust or lint on it, in which case you can use a CD cleaner disk (available at Walmart or Radio Shack, Best Buy, etc.). If that doesn't help, the second most common problem is that the laser lens is out of adjustment, and not focusing properly, thus not reading the CD. This can happen with slight wearing of mechanical parts, or any change in the detection circuity (aging of capacitors, etc.) This can be corrected, but it entails taking the unit apart and adjusting the CD lens on a trial and error basis (adjusting, then trying, until you get it right). Here's a web blog on the procedure, and it will clue you in on what you can try. If you don't feel like tackling it yourself, of course, you will have to have the unit serviced. Get an estimate first, since it's also possible that they will just replace parts, or possibly a circuit board, in the event that adjustment of the lens doesn't solve the problem. Here's the blog:
http://www.fixya.com/support/r4192169-fix_calibration_cd_dvd_drive_no_disc
Good luck, and hope this helps!
Posted on Jul 22, 2010
Why doesn't it record to md?
You can't make a copy of a copy of a digitally recorded MiniDisc, so make sure that isn't what's happening- if so, it usually says "Din Unlock" and you can't record. I think when I record from one deck to the other digitally, I have set the recording deck to "REC", then I hit 'play' on both decks at the same time. Using the digital input, it should automatically set your track marks. You cannot make a digital copy of this MiniDisc, BUT you can make an Analog copy. Let me know if you need more info.
Dec 11, 2015 | Audio Players & Recorders
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
I have a kenmore electric range model #790.9414 and after setting the proper time and hitting start, the time display goes blank after a few seconds and must be restarted.
This is a "feature" imposed upon us by those energy-saving freaks and environmentalist-wackos. What you need to do is press and hold the clock button for 12 to 15 seconds. When you first press this button, the display will appear. Then in about 7 or 8 seconds it will disappear. Keep holding it for 12 to 15 seconds until it re-appears. Now if you release the clock button, it should remain on.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 23, 2014 | Kenmore Kitchen Ranges
Message waiting light is flashing but no messages are recorded. I have turned this off at Options but message waiting display keeps coming back..what do I do.
There is a call back feature in the system. Sometimes when you receive an internal call from another extension and you are on another call the caller will hit callback. You actually have to return the call to that extension to stop the light from flashing.
Feb 28, 2014 | Nortel Computers & Internet
I have a Pioneer PDR 609 CD recorder. I put a disc in and it says Pro disc din unlock.
This is nearly always due to cable problems. I think the cheaper optical cables can get 'kinked' quite easily, which would stop the signal coming through properly. So, first check your settings to make sure the correct cable type has been selected. If that's OK, try replacing the cable with a good quality one.
Jan 02, 2014 | Pioneer Computers & Internet
Why i am seeing DIN UNLOCK
If you are recording from a DIGITAL input like the OPTICAL or DIGITAL COAXIAL and their is no signal, or if it is a 'non-copyable' copy of a digital copy (from a mini-disc or protected audio CD-R) you will see this. You need to record using ANALOG inputs, then you won't have this DIN UNLOCK problem using analog. Double check your digital connections and make sure your digital source is set to 'play' and see if the DIN Unlock goes off. Otherwise, use analog reocrding only.
Jan 18, 2011 | HHB BurnIt CDR830 CD Recorder
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Can not finalize disk
I have had loads of people ask me this question in just 2 weeks, so it often does happen okay?
Anyway you should not have to do a finalize on the disk, because when you stop filming, the camera reads it's end bit to the DVD auto, then after a few seconds you should be able to open the camera door.
May 29, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
My GC-821 pink mp3 player says ''no file'' after I synced my music (from windows media player). But it plays the music back to me on windows media player. Help!
Do NOT open the "RECORD" folder and put your music in it.
Put you music in the folder that opens. the "RECORD" folder is NOT for you to put music into. It is for you to get your .WAV recordings out of.
Ohhhhh, now you get it!!!!
Dec 16, 2009 | Element Electronics Audio Players &...
Teac CD-RW880 CD Player / Recorder Logo
189 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
