Question about Panasonic NV-GS10 Mini DV Digital Camcorder
Lcd blank/dead but camera is working
Lcd blank /dead everthing else is working including black and white view finder. I have opened the camera and had a good look but all the joining ribbons appear to be in good order, I have not opened the Lcd to have a look at the ribbon from that side?
Thanks
Dave Roberts.
JoeO700
  • 80 Answers
SOURCE: No picture in LCD
The most common problem I see in this camera is the LCD harness itself. A crease forms in the cable and opens the B+ line going to the backilght assembly. I would also check the chemical fuses located on the DC input board to see if any are open due to a shorted inverter in the LCD module. The open fuse will show low ohms to ground if the inverter is shorted. Good Luck my friend! Joe Weibel customelectronics.org
Posted on Feb 21, 2007
zohail
  • 1223 Answers
SOURCE: Panasonic lcd ribbon cable
u can order them email them the part discription they can send u one if u go to panasonic they will ask for a price of new cam
link for order or try ebay for this it iwll help
http://www.partmaster.co.uk/cgi-bin/search.pl?query=Panasonic%20NVGS35&pg=3&path=98821,112403:98828&brand=Panasonic&model=NVGS35&part=
you first need to strip both the camcorder and the lcd door to get the actual cable out. It might just push into a terminal connector at either end or it might be soldered to the circuit board at either end. Once you find that out then you could probably get a piece of ribbon cable to replace it from an electronic parts supplier. You also have the option (if you have a decent soldering iron) to just use standard multicore cable and solder a colour-coded set to replace the ribbon. If the board uses connectors you would have to unsolder that too and then make up your own cable loom using very thin cable.
It's a delicate operation requiring patience and a BIG magnifying glass ..I had to fix the ribbon cable when I blew up my LCD monitor...the terminals are really tiny but it can be done!!
plsw rate me FIXYA if i helped
Posted on Mar 28, 2009
  • 221 Answers
SOURCE: supercam ah dp800h powers on but nothing in the view finder
most likely problem is many defective capacitors on the video board.
Posted on Mar 31, 2009
  • 22 Answers
SOURCE: dvx100a showing black screens on lcd screen and view finder
You probably have the lens cap on, the iris dial closed, or you are in vcr mode rather than camera mode. You may also have the nd filter set to 1/64th, this is only for bright sunlight. When shooting indoors with low light, set the nd filter to off and hit the iris button until iris manual appears on the lcd, then dial the iris dial in front of the iris button up or down to bring the iris to around 5.6 f stop.
Posted on Aug 10, 2009
leecom72
  • 4806 Answers
SOURCE: when i flip open the side view finder, i get a
It sounds like the ribbon cable has worked itself loose either on the flip or the main body of the camera itself.
If you are confident that you can can take the camera apart and check the cables then all you will need is a set of precision screwdrivers, patience and steady hands as you will be working with delicate parts.
If your not confident with repairing yourself then i recommend that you take the camera to a specialist.
Regards.
Posted on Nov 09, 2009
My FUJI S7000, Treasured present from wife has failed.view finder and LCD are blank, all other functions ok.Also playback & downloaded shots produce a black image, behaves like a SLR whose whos shutter...
looks like you have a dead ccd, reset your camera , if this does not help bang hard with back of your to the base of your camera, last resort take to service for change of ccd
Mar 04, 2015 | Fuji FinePix S7000 Digital Camera
The viewfinder is blank and working only with review option. Since the viewfinder is blank the photo and video is also blank. Is it a firmware software problem.
Its a camera CCD Problem. If the View finder & LCD both showing black then its 100% CCD problem. Let me know Lcd also black? Also make sure lens is not covered by any thing.
Aug 24, 2010 | Kodak EasyShare DX7630 Digital Camera
My Sony Hc42 camera LCD, view finder gone blank
cheak ur lcd srip and there is a samll switch that chaing over switch cheak it
Jul 08, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
View screen is white (blank) with internal cracks
Look fo the switch that has two setting. one of them will say LCD and the other Migt EVF if you have a view through your view finder this is your problem.
Jun 28, 2009 | Samsung L200 Digital Camera
MY Hvx 200 Is totally Black when I turn it on. the display and playback of my old footage works fine but the picture is totally black. any Ideas When I switch the camera on, the view finder is totally...
You should go into the menu, camera settings and set the evf to on. EVF stands for electronic view finder. This can be set to be on when the lcd is open or closed. CAreful, if the evf is set to on and you point the viewfinder towards the sun, it will burn white marks into the viewfinder and ruin it.
May 09, 2009 | Panasonic AG-HVX200 Mini DV Digital...
Canon Powershot A70: LCD screen went blank - I can still access all menu functions (timer, resolution etc), but the screen is completely black otherwise. If i take a picture using the manual view finder,...
I had a A70 that would still take pictures, but the screen did not show a picture. I did some research and found that this is somewhat a common problems with some of the Canon Powershots to include the A70 where the LCD screens expire. I believe that if the camera gets too hot, such as being left in a vehicle the LCD seperates. I sent my camera to Canon and they fixed it for free. It took about 4-6 weeks to receive my camera back, and now it works perfectly. They did a great job on communicating with me, and fixing the issue. I think that alone is worth buying a Canon. The link below should help you.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=221&modelid=8776
Sep 27, 2008 | Cameras
The view finder does not wotk
Try pulling out the eyepiece, it will reveal a switch that controls the focus, it maybe the problem, good luck
Aug 13, 2008 | Panasonic Palmcorder PV-DV351 Mini DV...
SCREEN AND VIEW FINDER BLANK
Is the battery dead? Try taking it out and charging it, then put it back into the camera.
Also, you can try using another battery of the same type.
May 30, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Blank LCD screen
no screen display
Dec 01, 2007 | Samsung Video Cameras
Panasonic NV-GS10 Mini DV Digital Camcorder Logo
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
