I cannot get my universal remote to work!!! we have tried everything and it will change the channel once and then it doesnt work. i have tried all the combo codes and im getting really mad!!!!!!!!!!!
  • 4,102 Answers
Hi have you tried manually searching for the frequency like it says in manual untill it turns the telly off then store this frequency in the control if this still dont solve your problem then the remote is faulty because if your telly is listed in the code sheet then it will work on the telly if not then the control is faulty so take it back and get a replacement ok.
What make and model is your remote?
What make and model is telly?
let me know then ill look for you ok
Posted on Apr 22, 2008
Dont know to change channel for cable
If you have a universal remote it will have a button with CAB on it or TV, SAT, CAB, DTV,. Toshiba remote may only run the equipment it came with. Try using a universal remote that will work everything you have.
Aug 13, 2013 | Toshiba Televison & Video
I have a disney tv and the phillips codes do not work. Does anyone know of different codes besides 0417 and 0115:
Follow the same steps to enter a code but instead of entering code press the channel up button repeatedly until it turns the tv channel and when it changes (dont press up again or else you will have to do it over again). When you get the remote to change channel STOP! and press the enter/ok, or similar button to lock the code in and you should be set. Good luck. If you follow the steps and it doesnt work the first couple of times dont be discouraged, Trust me all universal remotes allow you to set up you universal remote this way i guess they already know people lose the universal remotes instruction manual with all the codes in it! Hope this helps GOOD LUCK too you. Hope this works out for you!!
Jan 02, 2011 | Disney DT1350-P 13" TV
My brighthouse remote can turn my tv on and off but not change channels
The remotes have several device keys at the top of the remote. They have abbreviations like "VCR", "DVD", "TV", "CBL". By default some actions are locked into a specific key. By default, the volume buttons will always control the TV volume and the channel buttons will always change channels on a digital box.
If you have a digital box, and the channels wont change, the default locks might have been removed. Consult the instruction manual that came with the remote and re-lock the buttons to the correct device key. Otherwise you will need to press the "tv" button when trying to change volume and the "cbl" button when trying to change channels.
If you do NOT have a cable box and are just simply trying to use the universal remote as a primary remote, you will need to unlock the global channel lock. Consult the manual for the remote or check online for the remote guide. The Company which makes the remotes is called Universal Electronics and you can find digital copies of their manuals on the Brighthouse Websites.
May 20, 2010 | Sylvania LC320SS8 32 in. LCD Television
Im trying to program my rca remote everything
You have to try another code....hope this was helpful...
Apr 28, 2010 | RCA 3-Device Universal Remote with...
VOLUME WON'T WORK USING REMOTE, BUT CHANNELS ARE TURNING. HOW CAN THIS BE FIXED?
First hit the TV button again and try and change volume, if that doesnt work try a different code as many codes can do some functions and not otheres.
Apr 16, 2010 | Universal Remote Control Remote Control
My remote is driving me CRAZY!!!!!!!
1) Manually turn on the device to be controlled.
2) Press and hold CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3) Press and quickly release the desired mode button (TV, VCR etc.) . The red indicator blinks off once.
4) Press the CHANNEL UP button repeatedly ( up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press the CHANNEL DOWN button to backtrack through the library until the device changes channel. Pressing CHANNEL UP changes direction forward again.
5)Press and release MUTE to install the code.
Hope it helps~
Oct 27, 2008 | Philips PM435S Remote Control
RCR460 with Emerson Tv doesnt change channel to input sources
found the answer but it doesnt help.......i got the number to who makes RCA remote controls and called them and talked to tech support to see what i could do for this problem. According to them, some universal remotes are compatible with most tvs but sometimes the remote can only give you the basic functions (chan up/down, volume up/down, #'s, mute an so on.) i dont really understand why it wouldnt work for the input channel but i do know i have a lower end and low priced tv. so....just like everything else the more you pay...the better it is. I checked the remote on my other tv in the living room and everything works just fine, even the input button. Hope this helps...
Mar 13, 2008 | RCA RCR460 Remote Control
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
