Our washer shuts off in the middle of a cycle and flashes the letters H and F. We can pause and restart, but chances are it will do it several times during the cycle. Any suggestions?
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Testimonial: "Thanks---you response was very helpful. I'm going to try it right now (although there is plenty of water in the machine--hmmm). "
