Question about Pioneer AVIC-Z2 Car DVD Player
Screen wont open
The screen wont open automatically, only manually. something is wrong with the mechanical drive. not to mention it wont shut all the way either its stuck 1/4 open. i thought it was just off track and when i opened it up and looked inside, i only saw 1 gear and a pulley(i, think), which makes me think a belt is missing. am i right? how do i fix this?
2 Suggested Answers
jestamac188
  • 79 Answers
SOURCE: my pioneer dvdrw dvr 107d door wont open when i
The drive may have come loose in your pc and is stopping the door to open.Hold open the front flap and press the eject button. If it wont eject your disk straighten out a paperclip and holding the front flap open look at the front of your drive and you will see a small hole.Push the paperclip through the hole and it will release the catch and eject your disk, You may have to push hard .Hope this helps you.
Regards Bill
Posted on May 04, 2010
Laptop PC - DVD drawer wont open
just try this !!
there's an small hole beside eject button on your DVD drive tray.
take a small pin and push it into this hole move it around it will open.
this is for opening DVD drive manually if something goes wrong.
try this if doesn't help then goto service center. Generally they won't charge you for this.
Jan 23, 2013 | Computers & Internet
When i leave my car on and parked it sounds like its going to shut off
You don't state whether the car is manual or automatic transmission (yes, the Taurus SHO was made during the 1990's with a manual transmission). The RPM's could be an indicator that your car needs a tune-up by a qualified mechanic. Regarding starting the car in neutral, if it is a manual transmission, it won't start in "gear", the reasons for that would be obvious.
If it is an automatic transmission, you DEFINITELY need to take your car to a mechanic. If your car has been worked on by a backyard mechanic, it may have serious problems that need to be corrected before something undesirable happens: I had a car once that would start "in gear" and it was an automatic transmission. I almost ran over my boss once because I forgot to make sure it was in "park" when I started it. That could have been tragic.
Nov 19, 2012 | 1996 Ford Taurus
Error 02 - 574
Main code 2X : Mechanism control system error
574 Failed to detect the T reel FG during search.
This means the take up reel stopped rotating during forward search. It shut down assuming tape was spooling loose into mechanism. Could be just a faulty cassette tape. A common problem is also when labels have been placed in the wrong places on the cassettes, stopping the lid from opening fully and stopping the reel reaching the reel motor drive.Manually eject the tape and try another tape. If the fault continues, have a look for something in the way under the cassette such as post it notes, paper clips, torn labels etc.
Have you had the unit serviced since you got it?
Could be time to get it to a service centre for help.
Aug 06, 2012 | Sony HVR-1500 HDV VCR
Shifts out of gear while driving
No mention of whether automatic or manual transmission......If automatic, check fluid level, if manual trans, something would be loose and trans needs to come apart to find it.
Jun 22, 2011 | Land Rover LR3 Cars & Trucks
Im having trouble with my maytag neptune tl washer it wont finish the spin cycle
Please see the following Whirlpool / Maytag service manual for Neptune washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
On page 3-1 the manual explains that if the washer shuts off during the spin cycle, the problem points to a weak spring in the door lock mechanism.
"Shuts OFF In The Middle Of The Spin Cycle:
During the spin cycle, the machine control
monitors the door lock mechanism to ensure
the door is locked. This is done through the
door lock enable switch. During "lock mode,"
the shaft of the door lock mechanism is
pressed forward by the door lock wax motor,
and the shaft presses in the button of the door
lock enable switch. If the machine control
board sees the switch OPEN during the spin
cycle, the machine control board will automatically
shut the washer OFF. This is caused
by a weak spring in the door lock wax motor.
Replace the complete door lock mechanism.
Oct 25, 2009 | Washing Machines
Brushes on hoover deluxe steam vac cvarpet cleaner are not rotating. Took out the brush assy and drive spins slowly but with little torque. Cannot seem to open the bottom to see if belt or direct...
(1) Assure the brush shut off lever on the hood is not set to the off position.
(2) Is there still a square pin standing up from the one drive brush? It should be 1/4 square, and about two inches tall. That pin is the drive from the transmission to the brushes.
There are no belts. The transmission is air and gear drive mechanism.
Oct 02, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Screen is showing EP
well im not a profesional on minis but yoru tranny may be going out i knwo i wont be able to help you on this one but id really get a authorised mechanic to look at that one cuz something may be seriously wrong and could leave you stranded on the side of the road and thats not fun trust me
Nov 14, 2008 | 2004 Mini Cooper
Change reverse gear
You didn't mention if automatic or manual but the first is something you aren't likely to do at home, the second, only if you are willing to buy a service manual and are very meticulous.
I've done several but don't advise anyone with no exprerience in dealing with precision mechanics to attempt it.
Jun 05, 2008 | 1998 Volkswagen Jetta
"Cover opened" error message
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Sep 14, 2007 | Kyocera Finecam L4V Digital Camera
Digital Camera wont load
Sep 07, 2007 | Konica Minolta DiMAGE G530 Digital Camera
Pioneer AVIC-Z2 Car DVD Player Logo
63 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
