Question about Maytag PTB2154G Top Freezer Refrigerator
Have a Maytag refrigator PTB2154GR. All fans are working and compressor is hot. Just cool air out from freezer and will not freeze. Could starter relay bad? How can I check it? Can hear clicking under refrigerator. Thank You Ted
catriver
  • 878 Answers
SOURCE: Amana bottom freezer/ refrigerator
Geezer, sounds like a defrost issue. I usually find the bi-metal to be the culprit on this model. Check out the pic. You will have to remove the back panel in the freezer and defrost the evaporator. Remove the ice maker if there is one. The back cover has 4 quarter inch screws. remove those. The air vent has 2 plastic clips one each side and one on the bottom, push in and pull the grill off. The thermistor cover has a slot for a flat blade screw driver,push in and pull the cover off. The thermistor will now slide behind the back panel. Check the bi-metal for buldging. As long as the evaporator fan is working, it's probably a defrost problem.
Posted on Jul 16, 2007
  • 159 Answers
SOURCE: Maytag MFD2561HEQ Bottom Freezer Refrigerator - Freezer working, refrigerator not
Marc of Nc. check to make sure the fan in the freezer is operating when the compressor is on. The only thing the fresh food section gets its cool air from is the freezer. and if the fan is not operating no cold air will get up there. If the fan is running you need to make sure the air duct is not blocked with frost of the evaporator is not iced up. Check that out and get back with me if there still is a problem. Good Luck
Posted on Aug 06, 2007
Krazytech
  • 725 Answers
SOURCE: Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Posted on Aug 18, 2007
watugot
  • 290 Answers
SOURCE: Maytag msd2454gr
The click is not normal. The compressor is not starting and is tripping the overload. There is a chance the start relay on the compressor is shorted, but most likely the compressor will have to be replaced.
Unplug it for several hours until the compressor cools down and then try it again, if it starts up ok when it is cool the compressor is the problem for sure.
If it is less than 5 yrs old the compressor is still covered by warranty and will be replaced free of charge.
Posted on Dec 07, 2007
mikedurland
  • 481 Answers
SOURCE: maytag refrigerator clicking
it sounds like a bad:
  • ·       start switch (on the side of the compressor) or
  • ·        compressor itself
the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Posted on Jul 06, 2008
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
Refrigerator won't cool less than 52 degrees
I can tell you if it can be fixed by you or if you need service. Just answer a few questions as we go through this. Pull away from wall and remove the lower panel. Feel top of compressor and see if too hot to keep your hand there or cool. Let me know if freezer fan and fan below are running. Answer those and that will help me answer your questions, Thanks Sea Breeze
Feb 15, 2010 | Maytag Admiral Top-Freezer Refrigerator
Maytag side by side issue: Refrig works normal. However the freezer defrosted itself, food is thawed. I'd like to repair myself, what's your recommendation i.e. troubleshoot, what to look for prior to...
Pull the refrig out , and remove the back panel . Is the compressor running ? Is it hot ? Is the fan cooling the compressor , running ? If the compressor is not running , the piece on the side , with 2 or 3 wires going to it , is bad . If the fan is not running , replace the fan motor . The part number for the compressor piece ( overload/relay kit ) is 12002784 . It is easily replaceable . If the compressor is running , check the square black coil box ( condensor coil ) , to make sure it is clean . Is clean , check the fan in the freezer , to make sure it is working .
Nov 22, 2009 | Maytag MSD2454G Side by Side Refrigerator
I own a maytag rsw 2700 refrig. motors run lights
Hi jtc1280 when you say motors are running,does that mean the compressor motor or is this just the cooling fans.
I suggest you remove the cover on the rear bottom to access the compressor motor and check the compressor by putting your hand on the compressor be cautious when doing this the compressor may be hot if not working correctly un plug the compressor and plug back up with hand on compressor see if you can fill the compressor running this motor runs with very little noise. If this motor is very hot insure that the colling fans are working and also that the condensing coil is free of lint build up which can make the unit over heat if this area has a lot of lint build up unplug unit clean the bottom out with air hose and vacuum if no air is available just use a dust brush to clean good let the compressor cool for 30 or 40 minutes before plugging back in.
Jul 07, 2009 | Refrigerators
No air movement in frig and does not cool or freeze
you need to get a tech to look at it it sounds like a sealed system issue Compressor,drier etc....
Nov 12, 2008 | Maytag MFD2560HES Bottom Freezer French...
DOOR JAM BETWEEN FREEZER AND FRIDGE IS GETTING HOT
This usually means that your condenser fan has stopped. That's the fan outisde (under or in back of) the fridge. It should be running whenever the compressor runs. Heavy accumulation of dust or anything that obstructs airflow could also cause it. But the most likely culprit is the fan.
Nov 05, 2008 | Frigidaire Refrigerators
Maytag side by side slowly getting warmer
YOU ARE BE GETTING A WEEK COMPRESSOR.
Jun 09, 2008 | Refrigerators
Frame where door seals is very hot
Fan should be running when compressor and fan in refrig. is running... replace condenser fan, compressor will over heat with out fan running, and refrig. cant get rid of the heat in pulls out of freezer.
Sep 12, 2007 | Maytag MZD2752G Side by Side Refrigerator
Aug 18, 2007 | Maytag MZD2766GES Side by Side...
Maytag PTB2154G Top Freezer Refrigerator Logo
239 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
