Acer Aspire One  PC Notebook Logo
A
Anonymous Posted on Jul 12, 2010
My labtop model aspire laser one N214 adapter damaged if i want replace a new one how i want to tell the it shop reagrding this they ask me abt the input & output..kindly reply.thanks.
Anonymous
Level 3:
  • Master 808 Answers
  • Posted on Jul 26, 2010
Anonymous
Master
Level 3:
Answers
808
Questions
0
Helped
142874
Points
1763
Vga driver
You can look in your bios if you didn't turn it off by chance.
Otherwise you erase it from your hardware and look for it again in new hardware and install.
11helpful
2answers
N214 drivers
on acer website search for model number. it is not n214. u will find it on back! something like AODxx AOHxxx
1helpful
2answers
Replace broken usb port on acer laptop
The usb ports are usually soldered to the motherboard, in some cases repair shops can re solder new ones to it but sometimes its best to just replace the entire motherboard. or in this case laptop
Aspire 5251-1513 ac adapter broke
Don't do that if you are not good for repairing laptop. That will damage your laptop and be dangerous.
Either repair your laptop adapter or buy a new adapter. If you can't let your laptop charger repaired by yourself, you had better replace a new charger.If you are on a budget on a new charger, consider buying a third party charger:Intocircuit Acer Aspire 5251 AC Adapter 65Watt 19V 3.42A
1helpful
How to reinstall window in acer aspire one n214 without cd and usb
Hello, the following solution WILL cause you to lose all of your current data on your Acer Aspire One. I typed this up myself, I learned from experience.
To do what you are asking, restart your Acer Aspire One, then while it is starting up, you should see a white screen that says Acer as seen below (Not my picture). I'm not sure of the key combination but try Alt+F8, Alt+10, or Alt+F11. You should see a black screen (As I remember) but wait about 2 or 3 minutes and Acer eRecovery Management. Follow the steps to do a factory restore. ALSO: If your computer does start up (Mine wouldn't) you can go to start>All Programs>Acer eRecovery Management and follow the steps there. Your Acer will be like brand new.
Hope I helped.
Startup Screen: dda10_1.jpg
Ihave acer aspire 5332 labtop but i don't now how i play blutooth in my labtop please help me now
You don't have bluetooth in that laptop. You must buy a separate USB dongle and install it. Here's one
http://www.amazon.com/Bluetooth-USB-Micro-Adapter-Dongle/dp/B001EBE1LI
Acer spair model zg5 n214 not work
how do i remove the keyboard on my acer aspire one ,Model No.ZG5?
What would it cost to repair the on/off switch on ew 100G2 sennheiser ?
To repair the on/off switch of the handhelt it would cost abt 15 minutes and $2,00 for the switch.
So that would be $20-25.
Reagrds Gerard
6helpful
2answers
Aspire One N214 Model # ZG5 keeps showing me a Acer screen before informing me that I have a Media test failure and that it has no bootable device. I have no boot disk it asks for, Please help me!
The media failure means either the hard disk has failed and therefore cannot boot up the notebook.
Try reseating the hard drive first, so it makes proper electrical contact. If it still fails to boot up, then go to the BIOS setup and check to see if the BIOS detects the hard drive. The BIOS may have a hard disk diagnostic program, if so then run this program to check the hard disk. If the hard disk is faulty, then a new hard disk is needed and install Windows on this hard disk plus the Acer's device drivers and your programs to get a working computer again.
Hi my name is Ahmed
motherboard is damaged you will need a new one to get this unit up and running
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
