Question about Staples Arrow T2025 Staple Gun For Flat & Round Crown
Staples will not shoot flat. Have to hammer them
Staples will not shoot flat. Have to hammer them down. Using 3/8
  • 112 Answers
Well most home hardware ones all do that if used on anything hard/heavy timber.....if it is a heavy industrial one it may need anew spring.
Posted on Jul 24, 2010
Powershot, heavy duty, forward action, staple & nail gun will not shoot staples
If you are referring to a Swingline powershot model 1000, you may try using the following staples for best results: True Value part # 659857 for 1/4" staples or True Value part # 660426 for 3/8" staples. You may also find these staples at Sears under the Sears part #: 1/4" is part # 74417 and 3/8" is part # 74418. I hope this helps, often times, using an incorrect staple will give you undesirable results.
Oct 07, 2012 | Tools & Hardware - Others
I have a stanley heavy duty stapler TC110. When I put my staples in, they don't seem to be catching. There is some black part sticking out of the end where the staples should come out. It looks like...
The staples load on the underside of the stapler.
Step 1 Push down and retract the stapler pushup mechanism.
Step 2 Position the stapler so that the moving hammer handle is down
and the staple exit is up
Step 3 Load the staples into the chamber on the bottom with the points up.
Step 4 Push the pushup mechanism into the locked position until it latches, you will feel the spring resistance as the staples are pushed into place.
Sep 04, 2011 | Powerfast Stanley TR110 Light-Duty Staple...
I am using an Arrow stapler modelT50p and 5/8 inch staples to staple artists' cnavas to a 1x2inch frames. but, the staples protrude too far and need to be hammered in. If I use the smaller 3/8...
An easy way to see if the 3/8 " staple would be snug would be measure how much of the 5/8 " staple is up after you use the staple gun. There is 1/4 " difference between the two.
Enjoy,
Wayne
Aug 14, 2011 | Garden
I am trying to staple screen on 1.5 inch pine frame with 1/2 staples, but I have to set them with a hammer. Am I expecting to much or is there a way to adjest it to run them in the who way /
I have found that staples will set well only if I use the palm of my hand to hold the front of the stapler down tight against the material as I operate the handle.with my other hand. Without holding it down this way the stapler tends to recoil a bit and the staples don't set all of the way. If that doesn't solve it for you, you could try using 3/8 staples, since the screen material is of negligible thickness. Good luck, Al K
Jun 01, 2011 | Ace Hardware Ace Staple Gun
I can't seem to reload staples into this stapler. I used the staples that came with it and it worked fine. I try reloading and it doesn't staple.
With the stapler sitting a solid surface, turn it 180 degrees so it is pointed away from you, and you are looking at the back. Press down on the plastic extension that you see (about mid-height on the stapler). This releases the staple-holding compartment (it shoots out the front of the stapler). Reload it with standard staples, push the compartment back in place until you hear a click. Voila!
Apr 15, 2011 | Staples One-Touch DX-3 Desktop Flat Stack...
A staple jammed in the moving part (driver?) when using to staple. How do I clear the jam?
first remove the the spring loaded rod that keeps the staples in place and tight, if you can see any part of the jammed staple , grab it with pliers or vice grips and pull it out any way you can , might be more than one staple jammed too, turn stapler upside down to dump out any loose staples and debris , keep working until she frees up , if you still cant get it out might have to loosen screws up that hold it together, a little light lubricant will be good for it too . then load it back up with staples and put tension rod back in, i always try to keep it full of staples at all times ,like when it gets 2/3 empty , fill it up, this will ensure good tension on the business end of the staples!!
Feb 05, 2011 | Heavy Duty Arrow Ht30 Light Wire Hammer...
My gun will not shoot staples after loaded I thin there is a part missing
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Hope it helps!
May 02, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Cannot load staples
At the back of the staple gun is a flat shaped metal piece. It's at the bottom. Push in, pull down, then pull the mechanism out. You'll see it's a metal rod with a spring, that is attached to that flat metal piece. The spring pushes against another flat metal piece, that has a hole in it, and travels back, and forth on the rod.
The flat metal piece that the spring pushes down the rod, pushes against the staples.
Remove this spring mechanism, slide the staples down the rails. The staples will be in the position of an upside down U. Replace the spring mechanism, and lock it back into place. (Push in, pull up)
Should, your question be in reference to the fact that you have staples loaded, but upon pressing the trigger nothing comes out:
In the front of the staple gun, is a flat metal piece that pushes down on the staples. One staple at a time. The flat metal piece is shoved down by spring pressure. The spring pressure is applied to the flat metal piece each time you squeeze the trigger. (Flat metal piece = Hammer)
Sometimes, Two staples try to come out. When they do, this flat metal hammer is stuck up in the gun. To free the flat metal hammer, remove the spring mechanism out of the back of the staple gun. (The spring mechanism discussed above) Remove any staples in the gun.
Try to use a flat blade screwdriver, and see if you can shove the flat metal hammer in the front of the gun -> UP.
(DO NOT have the staple gun pointing at your face! DO NOT squeeze the trigger! DO NOT use excessive force)
If this method is of no avail for you, you have to disassemble the gun, and remove the metal hammer, and stuck staple/s.
Jul 29, 2009 | Arrow T50P ARROW STAPLE GUN
Staple gun has staples but quit working.
I hae the same problem. I don't know the real names of the parts so I will make up my own and try to describe them. The problem with mine is that the "hammer" (the piece in front that slams down on the staple and shoots it out) is broken. The "hammer" has two notches that the tension spring (actually a metal bar with two tongs not to be confused with the spring the returns the handle to the at rest position) fits into. One of these notches on the hammer is broken. Therefore one side is not attached to the tension spring the causing the other side to slip off and since the hammer is not connect to the tension spring you get no resistance. Unfortunately I could not find anywhere that sells a replacement peice.
Sep 18, 2008 | Black & Decker 5700 Powershot Forward...
Staples Arrow T2025 Staple Gun For Flat & Round Crown Logo
236 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
Van Allen II
Van Allen II
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
