Question about Kenmore Washing Machines
Water level will not fill up for a full load. Machine is 15 years old. Water level only goes to about 1/3 full. Will not cover clothes.
    President:
  • 1,430 Answers
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. There is a video at http://appliancehelponline.com/toppressureswitchvideo.html this will walk you thru the inspection and replacement of this part. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on Jul 22, 2010
New Samsung Top Loader13kg WA13J571 Wobble Techn,used for the 1st time-water level 1(LOW)still filled the WHOLE machine with water.Bigger load on level5(FULL)never stopped filling with water.
use the features fuzzy logic, u only need to power on and start on the machine when u hve fill in the tub with cloths and soap. water will fill in according to the load filled.
Sep 08, 2017 | Samsung Washing Machines
One piece agitator wraps cloths
When loading the machine, load towels, sheets or jeans with an accordion fold instead of putting the laundry in a circle around the agitator. It helps to put the clothes in at the twelve o'clock position, then six o'clock, then nine o'clock and then three o'clock. Repeat this sequence until the washer is full.
The laundry can circulate much better and get cleaner too.
Feb 08, 2014 | Washing Machines
New Hotpoint washer purchased Nov.2010.....Problem 1. Fills, agitates and "drains" NO SPINNING this cycle. #2. Rinse fills with ONLY ABOUT 6-7 gallons of water, agitates about 10-15 seconds then...
may have a bad pressure fill switch and thats the reason not filling all the way have you tried on different load sizes... if this is a top load unit need to check the fill hose that goes from side of tub to pressure switch in console make sure has no cracks or kinks in it... what happens is water fills tub and then pressure from tub water goes up clear plastic hose to pressure switch to tell it to advance to next cycle... may be your culprit. and causing other problems... as far as clothes tearing beware hotpoint had a issue with there tubs coming loose the nut that holds down tub will back off causing exess movement and will allow clothes to get under unit... this unit should be still under mfd warranty... call g.e and get a servicer out there to look at it.. at worst you may have to pay a service charge but parts should be covered along with labor.... good luck pleae vote./...
servicer for 18 yrs heating /air / and all major appliances g.e authorized and lg. authorized for 8 years
Jan 03, 2011 | Hotpoint Washing Machines
Washer didnt fill when turned on, but filled when holding "reset"
sounds like your water level switch is bad OR the small hose that goes from the waterlevel switch to the bottom of the tank has a hole in it.Try replacing this small hose first.you can go to an auto parts store and match it up.it's usually about 3' long and about 1/4" inside diameter and about 99cents a foot.
Aug 26, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Washing maching not filling with water
The problem is most likely the water fill sensor switch. If it is telling the machine that it is full, it will go right to agitate.
Apr 25, 2009 | Roper RAB2121KW Top Load Washer
My washing machine is leaving little residue on all my clothes after a complete wash, What are they? and how do you get rid of it, the washing machine is not yet a year old
Describe the residue. If it's oily (black, dk green) then the seal is out of the tranny and oil is getting into the tub. Dry cleaning is best for oil based stains. Liquid dish detergent is good also. On white it is tough to remove. Your washer will need a new transmission or replacing.
If it is powdery I'd guess a soap buildup, especially if you've recently changed detergents. The new detergent is breaking up the old soap scum in the outer drum and it is redepositing onto your clothes. This should wash out/off.
Tip: If it's a soap residue, fill washer full without clothes with hot water. Add 1 gallon white vinegar and more hot water until the unit if as full as possible. Agitate 15 minutes and drain. Rinse with a full level and drain.
Jan 24, 2009 | Samsung SW62ASP Top Load Washer
I have a 4 year old Maytag Performa washing machine. Regardless
Hi!!! You seem to have a bad water level switch..If you turn on the water and water just fills in and doesn't stop then you have a bad water level switch..If you just turn it on and water enters then you have a bad water valve..Good luck..
Jan 03, 2009 | Maytag Washing Machines
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite HE3 washer
set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
Washing machine
it has a little semi clear or black 1/4 of inch, long hose behind the control panel , who its attached one side to the level pressure switch and the other side to the tub. culd be only this three options clogged ,bented or unnatached this hose to one of the sides tub or switch easy fix
Jun 10, 2007 | Kenmore 20172 Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
