Question about Samsung RS2534 Side by Side Refrigerator
Samsung Refrigator I have A Samsung Refrigerator Model # SR-52028cVW The power is on the light is on in the Refrig. the compressor not running
  • labarry Sep 14, 2008
    I just got a Samsung French Door refrigerator. There is power to the fridge and to the door where the temp is displayed. But when I press the button to change the temp, the number changes for 5 seconds an then goes back to the 'Of" position, which I assume means off. Neither side is cooling at all, however the light is working inside.
  • lauratarque Sep 15, 2008
How do i fill up the water and ice maker
Posted on May 09, 2008
  • 101 Answers
The relay is bad or freon.
it have no
Posted on Apr 22, 2008
Have a kitchen aid side by side refrig that stopped working tonight. Model KSRB25FH with ice maker. Noticed ice was wet earlier today and tonight food has thawed in freezer section and refrig was not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 07, 2011 | Microwave Ovens
The refrigerator does not work. Fans do not run, compressor does not run, lights do work. Also board for water dispensor works.
From your brief description if only the compressor and fun is not working then you need to replace the thermostat control. Part No 3
Control assy., temp.
Part Number: AP4069609 made by WHIRLPOOL
You find this and all other parts of your fridge in this link and you can even order the parts directly.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48147&diagram_id=668775#d668775
Oct 17, 2010 | Maytag Matag 25.6 Cu Ft Side By Side...
Hi, we have a GE refrigator. We are just back from vacation and the freezer and cold area are not working. The lights work and power seems ok.It was purchased April 2000. The model number is: TPX24PRBJWW....
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 13, 2010 | GE Refrigerators
Roper model RT18DKXDN10. The refrigerator is running but is not getting cold. Seals around door are good, light goes off when door closes. The refrig is outside on our deck. It worked fine but stopped wkg...
heatman101
Aug 13, 2010 | Roper Refrigerators
The refrig motor starts but the refrig is not getting cold.
Hello,If the refrigerator is not getting cold, you need to answer some question.
1. check if the compressor is running.
2. Is the thermostat knob turn to the proper setting?if not reset it. then see if the compressor motor is running. The compressor is a football-sized case with no apparent moving parts,it's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of these components.
1. The compressor
2. Thermostat
3. The overload, relay, or Capacitor
4. The defrost timer
5. The condenser fan motor.
Thanks
Jun 21, 2010 | Sanyo 4.4 cu. ft Counter-High...
SHUT DOWN WITH TEMP SWITCH IN REFRIG COMPARTMENT, UNIT WILL NOT COOL, POWER OK LIGHT ON FANS RUNNING.
Sounds like the overload/relay , is bad on the compressor . This piece just plugs on to the side of the compressor . Take your model number with you to get the correct part .
Nov 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Model GSS25TGNB CC died
If you do not see frost on the inside rear wall of the freezer , Poll the refrig out from the wall , and remove the back panel covering the compressor . If the compressor is not running , Remove the 8" X 10 " panel , just above the large panel first removed . Unplug the refrig . Remove the control board , and on the other side of the board ( soldered side ) , look just behind the small black boxes ( located on the other side ) and look for a joint which has become unsoldered . Resolder this spot and reinstall the board . Plug the refrig back in , and see if compressor starts . OR , you can replace the control board pt # WR55X10656 .
Sep 19, 2009 | GE Profile Arctica Stainless Steel Top...
Refrigator compressor motor
No fuse. Check for retracted pins in molex connectors in back. See if any pins are sticking up farther than others on side of plug where wires enter. If so unplug connector and push wire in. Re-connect and recheck. Also have seen this in connector in console on left ceiling of refig. section.
Nov 15, 2007 | Frigidaire FRS3R5EMB Side by Side...
Samsung RS2534 Side by Side Refrigerator Logo
229 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
