Question about LG WM1812C Front Load Washer
Missing drain hose
When I moved into my apartment and examined the LG front-loader washer/dryer, I noticed that the little hose you're supposed to use to drain the water before you empty the lint trap was missing. So now every time I want to empty the lint filter, I have to put down a towel to catch the deluge of water. Could the hose have retracted back into the machine? If so, is there any way for me to retrieve it myself?
Thanks!
~K
  • 489 Answers
Yes, there are 2 ways to do it.  The easiest way works only if the washer is NOT on a pedestal.  Pull the washer out and tilt it back.  Have someone you trust hold the washer leaned back while you crawl underneath the unit. Look for the 3/8" rubber hose and just shove it back into the hole where the drain hose is supposed to go.  If that doesn't work, then you will have to disassemble the top, the control panel and the front panel to get to the hose.
Posted on Apr 28, 2008
My LG WM2650HWA front load washing machine is 13 months old. A few weeks ago I noticed water at the end of the cycle in the front of the machine. Upon further inspection I noticed soapy, water at the
It's very common for the sump hose to have a hole in it causing it to leak. The quickest way check is to tip the washer back and examine the sump hose by stretching it, as you stretch the hose you should find your leak. You'll also want to check the door gasket for cuts and the drain pump assembly for leaks. Let me know what you find.
Sep 28, 2014 | LG SteamWasher 3.6 Cu. Ft....
Lg tromm front loader washer wm0532hw shows oe error
that's draining error. check the filter cleanout behind lower left panel on front of machine; of course drain 1st via small drain hose. if thats o.k the drain pump itself may be jammed with debris or the drain hose could be clogged.
Jun 24, 2010 | LG WM-2277HW Front Load Washer
My LG front loader is washer leaking water.
Could be the bladder from the drum to the door of the door seal. It could also be the drain pump hose.
Sep 13, 2009 | LG Washing Machines
MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
May 06, 2009 | LG WM2277H Front Load Washer
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
Front loader LG Washer
make sure your outlet hose is not constricted or blocked in any way.
May 20, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Re: lg wm1812
There is a vent at the back of the machine near the top that is covered by a small round white plastic cross pattern. Inside of the machine there is a black flexible hose that attaches to the vent from the top of the outer tub. inside of the tub attachment point is supposed to be a light blue plastic valve that looks like an old style army helmet on a peg. The peg fits into a flange in the opening on the outer tub. If this valve is missing water will escape from the vent on the back of the machine. Another likely point of water leak is a loose inlet hose or missing washer on the inlet hose.
Mar 14, 2007 | LG WM1812C Front Load Washer
LG WM1812C Front Load Washer Logo
156 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
