Question about Brother MFC 210C All-In-One InkJet Printer
Printer paper feed does not work. How can i
Printer paper feed does not work. How can i repair the printer paper feed?
    Brigadier General:
  • 10,406 Answers
You could pay a qualified printer technician $50 to $75 to try to fix it, or you could "invest" that money in a new printer -- such is the nature of today's "disposable" society.
Is the printer still under warranty?
Posted on Jul 22, 2010
My hp officejet 6500 (E709N) will not feed paper from the feed tray. I just hear a stuttering sound. I can manually feed the paper, Is there a schematic or repair manual available?
No there is no specific repair manual for this, I have the same printer with the same problem. The problem is the pickup rollers responsible for the paper feed. And the printer does not dissemble easily without breaking something. I tried. you can send it to HP for repairs for a fee but they won't guarantee that they will able to fix it
Nov 03, 2016 | HP Office Equipment & Supplies
Paper will not feed normally into printer. No paper jam and everything else seems to work? how do you fix this?
If you can't feed the paper, I would say that nothing works. You haven't indicated tha make and model of your printer but all current pronters are made of chep plastic. When any small part gets weared off or breaks, it simply stops working. Repair shops get for manufacturer a "repair kit" and they know what should be replaced, so if you don't know how to repair a printer and don't have access to parts, your only solution is take it to repair
Jun 24, 2015 | Office Equipment & Supplies
My Epson R230x printer get paper james and not feed paper, how can I solve or repair this problem
i want to know. printer back side some gape i see. but i don't know which work do in this back side.
Nov 04, 2012 | Epson STYLUS R230 InkJet Photo Printer
The paper won't feed. I've repositioned the paper and it still doesn't work.
Check to see if the paper feed rollers are turning that push the paper into the printer. If so, then clean them with a soft cloth (not paper towels) moistened with alcohol. If they don't turn, you may have an internal problem and it would not be cost effective to get it repaired, considering how much new printers cost.
Feb 18, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Misfeed from the rear tray. The rear tray feed is not working. When it tries to feed it bends the right corner of the paper and then I get a misfeed message. I can't use the printer to print 4x6 photos...
there could be a teenie piece of paper stuck in the feed path causing this to happen, you have to visually inspect and ensure it is clear. Use plain paper to test.
rollers may also contribute to problems with feeding paper its good you tried that too.
lastly maybe the photo paper is too thick for that printer?
Apr 11, 2017 | Canon PIXMA MX700 All-In-One InkJet...
Paper Feed Tray will not feed paper. There is a
goes through below link and download the manual and try to clean the paper pick up roller and check i think it will solve your problem .......
Dec 14, 2009 | Brother DCP-7020 All-In-One Laser Printer
Paper feed catches on right side
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 21, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
My HP 1610 thinks there's a paper jam - when there isnt one.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Jan 16, 2009 | HP PSC 1610 All-In-One InkJet Printer
Printing
it needs fine adjustment to printer by service center.
Sep 15, 2007 | Sharp EL-2630P Calculator
Brother MFC 210C All-In-One InkJet Printer Logo
189 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
