Question about Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum
Windtunnel self-propelled feature broken
Hello, Any advice on the self-propelled feature? Mine is now whining/screaching and smells like it's burning up. I see the bar in front gets "stuck" ~ will changing the drive belt help fix this problem?
    President:
  • 1,673 Answers
If it is a rubber smell, then it could be belts and/or brush roll. If it is an electrical smell, then it could be the motor. Take the belts off and see if it still makes that noise, if it does, then the motor is going bad.
Posted on Apr 22, 2008
Why won't hoover wind tunnel self-propel?
Hi there! The self-propelled feature is controlled by a belt. Check the belts on your Hoover Windtunnel by following these quick steps.
1. Recline the handle. Lay the cleaner fat and flip it over to expose nozzle base.
2. Remove the screws attaching the nozzle.
3. Check that the belts are not broken, stretched or damaged.
Replace the belts if they are damaged. Hope this helps!
Jul 04, 2014 | Hoover Vacuums
Hoover Windtunnel repair manual
click this link below to see repair video for self propelled mechanism
http://www.youtube.com/watch?v=K722IsUxjYM&feature=related
Sep 03, 2012 | Hoover Vacuums
Just replaced the belts on my Hoover Windtunnel II self-propelled vacuum. The brushes are now turning ok, but the self propelled feature is not working. Squeals when when you lock it in the upright...
Check the plastic part, which the the self propelled cable is attached to. (release the handle, tilt it back. You should be able to see the cable attached by a screw to a black plastic arm.) It is either broken or the cable is lose.
Nov 14, 2010 | Hoover U6630-900 WindTunnel Bagless...
Self propel wheels not moving and smell like burning rubber coming from the back of the vacuum. How do you get to the belt to replace it?
I believe that you're asking about the Hoover Windtunnel Self-Propelled upright, but I can't be sure. I've posted a video below that we recorded showing how to replace the belts on your Hoover WT. If you have a different model then this, please just add a comment to this repair of the make and model and I'll be more then happy to walk you through.
Thank you,
Chris J.
GoVacuum
Apr 10, 2010 | Vacuums
I have a windtunnel vacum cleaner. When I
It might be a slipping rubber belt, is the brush roller moving when you look underneath? If it's a self propelled machine there might be another slipping belt. Friction from fast rubbing rubber can smell like it is burning.
Jan 16, 2010 | Hoover Company Wind Tunnel U53019 Upright...
Self propelled feature does not work. I replaced
There is a cable from the handle down to the transmission on this machine that breaks all the time or the cable is mounted to a plastic piece that is broken. That will need to be replaced.
Nov 28, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Hoover wind tunnel u5755-900. smoke, smell. self-propel
Can you verify the model number? However, based on your posted description, it sounds like the flat belt is either broken or fell off. to access the belts turn it over and remove the bottom plate (4 screws). the Flat belt will connect to the motor shaft in the back and the large black pulley.
Mar 13, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Hoover Self-Propelled WindTunnel Bagless Upright VacuumVacuum Logo
244 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
