Question about HP Compaq Presario SR1950NX PC Desktop
Fans are loud and no picture on screen but everything hooked up correctly
Probably the VGA Card is defective, try to replace it. Try to clean the fan from dirt but be careful not to touch the motherboard components.
Posted on Nov 02, 2010
Replaced motherboard and now fans are loud and fast
Check for proper connection, also check bios speed on fans and make sure heat sink is correctly installed... side note you have fresh item's and higher power faster speed... if there is a controller on fans lower them.
May 05, 2012 | HP KQ495AA Pavilion A6500F Desktop PC
I changed the power supply on my acer aspire e700 and it beeps continuosly non stop with no picture on screen, the last power supply blew. it had a graphics card when i bought it but it stopped working so...
You may have more problems than just he power supply from when the old power supply went out. The mainboard could be bad.
Make sure it's unplugged from power from the wall, then check that the memory is seated correctly. Check for anything else that may be out of place or not fully connected.
There are also different beep codes for different errors. They've mostly been standardized, but may vary by mainboard as well. Here's a link to common POST beep codes and their meanings:
Computer POST and beep codes
May 19, 2017 | Acer Aspire E700 PC Desktop
I have a 50" flat screen tv. Sat dish is hooked to
Hi!
Of course it is important to make all connections right, and I assume, since you have sound, that you did all the wiring OK.
But also important is to orientate very precisely the sat dish. In order to do so you need some devices and skills. Better ask a local professional to do that.
Best regards,
Bogdan
Aug 27, 2011 | Panasonic Televison & Video
I have power to the board, but i cannot get it to boot
do you have ram, hdd, fans, and everything else connected in the correct place? what about the bios, did you hook power to that?
Sep 19, 2010 | ASUS P5PE-VM Motherboard
When I use the HD input on my mitsubishi, everything on the screen is green???
When your picture has a green shade to it when connected through component video cables(red,blue,green) that indicates that you have the red and blue switched around at one end, since you have a picture, that indicates that the green cable is hooked up correctly, if the picture color isn't corrected after you make the switch, then make sure you don't have a bad cable.(it happens more often than you think) Good luck !
Jan 05, 2010 | Mitsubishi WS-65809 65" Rear Projection...
No picture anymore
I found one of these at the dump with the same issue. Bought a Z sustain board for $75 , replaced it and it works great. I plan on installing some PC style cooling fans in the cabinet as heat is what destroys these sets
Sep 08, 2009 | Akai PDP4273M Television
Brand new G31M3 V2 MSI motherboad, fresh out the box. I hooked up all the wires correctly (i triple checked them) and installed the new graphics card, wireless internet card, and tv tuner card, and...
Remove everything except CPU and 1 stick of RAM. Attach monitor to onboard graphics and under Integrated Peripherals in BIOS there SHOULD be option for display, it needs to be set to PEG so it looks for a PCIe graphics card first. If you still get no picture, DOA motherboard.
Aug 28, 2009 | MSI G31M3-L V2 Motherboard
No picture for playstation 2
Could possibly be that it is not connected up correctly, or your playstation has died. If you have access to another playstation, hook it up to your cables as they are hooked up. If the screen works. Your playstation has died.
If not, and you have the same issues, try their cables, and if that doesn't work. You have it plugged in incorrectly.
May 01, 2008 | Sony PlayStation 2 (PS2) Console
Astar flat screen monitor
i need help getting my astar flat screen tv to power on. the blue light is on in the center of the tv
Dec 24, 2007 | Astar LTV-2701 27 in. HD-Ready LCD...
HP Compaq Presario SR1950NX  PC Desktop Logo
90 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
