Question about Dell Latitude E5400 Notebook
Whenever my dell latitude 5400 is running on battery it keeps freezing but on power it is working fine. when it runs on battery then no process is smooth like when am mouse repointing mouse from one place to another then it is getting stuck in between and it became very slow to response but when running on power everything works fine
  • 435 Answers
The first thing we need to do is to swap another working battery with the existing one and see if the issue re-occurs. I suspect it to be a faulty battery.
Posted on Jul 22, 2010
Dell problem freezing
Not much to work with. Try shutting down unnecessary processes. It would be Helpful if we knew more, What were you doing when it froze? Perhaps it just needs some Cleaning and tuning up? Tow many running processes? Here are some Windows XP speed up tips: http://www.wikihow.com/Speed-up-a-Windows-XP-Computer
May 11, 2013 | Dell l Latitude 620 9300 9400 1...
Hi my Latitutude D800 has a Pentium M 1.7 GHz processor but it slows down and runs at 600 MHz. Please Help PS. Am using windows 7
whenever it use on battery power it shows it minimum speed, also it will shows full speed when the processor is processing something.
May 12, 2012 | Dell Latitude D800, PP02X Series Laptop...
My Dell Latitude D620 laptop will not boot up unless I hold the power button down. The computer will run fine if I keep holding the power button down. It will also keep running if I hold down any key. As...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Oct 04, 2011 | Dell Latitude D620 Laptop (Latitude-C620)...
Mine is dell latitude d620 laptop.battery is new.problem is it was running both on ac and battery.suddenly battrey is not taking the charge but my laptop runs on ac power. can i remove the battery and run...
the batteries eventually wear out and quit taking a charge. You can run the system without a battery with no ill effects. replacements are about $100 for a new battery
Sep 27, 2010 | Dell Latitude D600 Notebook
Dell d600 freezes intermittantly
sounds like the hard disk drive is slow to spin up. Sometimes older drives don't get all the way up to speed at boot, then with repeated restarts, the drive warms a bit and the spindle friction drops allowing full speed on the drive.
Try running HDD Diags the 1st boot of the day Fn +power button, see if you get any diag failure. Generally, a drive has to be within 3% of rated drive RPM (5400 or 7200) to function
Jan 11, 2010 | Dell Latitude D600 Notebook
I own a Dell Latitude XP2 Tablet Notebook. It has been working fine for over a year until recently. Now it's been freezing on me after a little bit of use. Sometimes I can use my computer for about 15...
the light next to the Battery LED is the hard drive activity LED (HDD, Battery, Wifi, Bluetooth)
http://support.dell.com/support/edocs/systems/latxt/en/html/about.htm#wp1206073
Off hand, I'd say overheating is a possibility so try using a can of compressed air to blow out the cooling vents and also run diagnostics on the cooling fan (Power plus Fn key to enter diags) If diags finds a hardware issue call Dell Tech
Nov 28, 2009 | Dell Latitude XT2 Tablet PC Notebook
My dell latitude d600 keeps freezing no matter what i'm doing after a few minutes. I reinstalled windows and it still continues to do the same thing. Some one please help!
Check your RAM size, if this is a hardware problem, you will like to check your RAM first. Apparently, your hard drive is moving/functioning, you may have half of the RAM fail on you! and for our technician help contact us at http://tinyurl.com/mtgjzz
Jun 22, 2009 | Dell Latitude D600 Notebook
Dell 610 - battery will not charge and adapter goes "blink"
http://support.dell.com/support/edocs/systems/ins6400/en/index.htm
aneesnv@msn.com
Dec 18, 2008 | Dell Latitude D600 Notebook
Dell Latitude C540 screen goes dark when adapter is pluged in
Right click on the battery icon on screen and set the power and screen brightness as you require.
May 02, 2017 | Dell Latitude CP DC Board Graphic Card
Dell Latitude E5400 Notebook Logo
115 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
