Question about Samsung LN-S4692D 46 in. LCD HDTV
Installation of t-connector board in samsung tv
Samsung led tv - turns on,audio ok, no video, backlight on
Sounds like T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 30, 2015 | Samsung UN65C8000 TV
TV not recognizing that any source inputs are plugged in.
Check your installation: it looks like you didn't put every connector properly. If that doesn't help replace mainboard in the store: may be it's faulty.
Apr 24, 2015 | Samsung Televison & Video
I have a 50 in samsung plasma tv and it sudenly had a 2in wide black and colourrd line from top to bottom appear ? any idears
try and bend the set slightly. IF line goes away suspect ribbon cable connector from x driver boards to panel. The connectors brake away from panel and thus a replacement panel must be installed.
Feb 18, 2011 | Samsung 50 in. Plasma TV
I have a samsung 40 lcd tv that needs a motherboard replaced how can I do this
Do you have a replacement board? What exactly is a motherboard in the tv? The main board with cpu? Open the back of the set and take digital pics of everything there with close up shots of the main board and all its connectors so you will be able to re-assemble the same way. Don't trust your memory. Unplug the set also, use an anti-static work surface and grounding strap. disconnect the wires to the board first then remove the screws holding the board. Don't drop or loose anything in the set. Install the new board and screw it into place, re-attach the wires. Plug it in and try it. If it works, re-install the back.
Mar 22, 2010 | Samsung LN40B530 40 in. LCD HDTV
Locked panel on my TV
open up the television and disconnect the power board connectors and the connectors to the audio digital board --- then reconnect them and re connect the power cord - this will reset the television as it came from the factory
Feb 27, 2009 | Samsung Televison & Video
The HDMI connector broke loose from its mounting inside the tv.
hi there, you can just re solder the points onto the board once more without buying a completely new board. just remove the board and solder the contact point back on the board itself.that should fix it up for ya. thx for using fixya:)
Feb 08, 2009 | Samsung LNR269D 26 in. LCD Television
Samsung LN-T3242HX LCD TV
Hi Compgeek09
Please check CCFL is hooked in connector properly, all connectors of back light inverter board are plugged correctly, check also other connectors of removed boards while CCFL replaced.
It doesn't seem issue of back light inverter board nor its related to ground wire of power plug to wall because tv was working before replacement of CCFL.
Oct 19, 2008 | Samsung LNT3242H Television
Samsung Plasma-Flat cable connector-CN5502 little bit torn
Sorry to say that the cable that you tore is not replaceable it connects directly into the panel. The fix is to order a new panel and move all the boards from the old one over to the new after installing it.
Sep 30, 2008 | Samsung HP-R4262 42 in. Plasma Television
Akai rear projection HDTV
the convergence board is available from vancebaldwin.com. The part number is BP95-00142E. It came shipped to me for $78... It is simple to install. Take off the lower back of the TV. The board comes out with one screw. You have to plug in the three tubes, a connector to the main board, and a power supply. On mine the connector to the main board matched up with wires and pins, but the connector was slightly different. I had to shave off one thing to get it to fit into the slot. Very easy install. Please note that the board is for this particular TV only. If you have a similar TV it probably is the same problem, BUT, the part number is also probably different. Do some research... You'll find the part. Vance Baldwin is a Samsung parts dealer. They'll have it...
Feb 08, 2008 | Akai PT4298HD Rear Projection Television
Samsung LN-S4692D 46 in. LCD HDTV Logo
57 people viewed this question
Jerry Greenberg
Jerry Greenberg
