Question about Zanussi 24 in. ZSF6160 Free-standing Dishwasher
Got a zanussi dishwasher zsf6160, lights working but none of the programmes are starting, not taking in any water?
    Sniper:
  • 174 Answers
If you can here the drain pump run at the start the fault is with the water valve or blockage in the side tank on the lh side. if you dont here the drain pump it possibly the heater thats down to earth. the electronics can detact it and not start the prog if heater faulty.
Posted on Jul 22, 2010
Zanussi ZSF6160 Water not heating
Mantona, you're on the right track. Your heater terminals are large, insulated and poke through the tub facing downward. To test this, remove one of the wires connected to the terminal, then check OHMS. If this is what you did, you don't have to do that again. Elements rarely fail, the problem most likely resides in the hi-limit thermostat. You know where the element is, now follow one of the wires back toward the control panel. One of the element wires will pass through the thermostat (in series) before going to the control. The thermostat is mounted tightly to the bottom of the tub, touching it to monitor temperature. When you find it, remove one of the wires (there are 2) and check OHMS. You should read ~1 Ohm, if you read infinity, you found the problem. (You can verify your finding by removing both wires from it and connect them together. Then run a wash load to check the heater. Don't leave it in this condition! The thermostat is a safety device and should not be permanently bypassed! If your test of the t'stat proves that it's OK, you'll have to test it with power on and running. I can walk you through this if needed. Let us know how it turns out.
Aug 16, 2007 | Zanussi 24 in. ZSF6160 Free-standing...
Water not coming into machine
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Oct 25, 2010 | Zanussi 24 in. ZSF6160 Free-standing...
MY DISHWASHER IS NOT GETTING HOT
If it used to get hot then I would check your water heater then the hot water supply connection to the dishwasher
Jun 21, 2010 | Zanussi 24 in. ZSF6160 Free-standing...
I have a Zanussi ZSF 6160 dishwasher which is not heating the water. I've checked the PCB and visually it appears ok. How do I change the heating element?
measure the heating element resistance it should be around 25 ohm.
otherwise it is the problem.
You can replace the relay, sometimes it stop working with no external damage signs
Jan 08, 2010 | Zanussi 24 in. ZSF6160 Free-standing...
Dishwasher running on cold water
that will be the callrod heater at the bottom look at it in the bottom to see if you see any cracks
not an easy job
Apr 17, 2009 | Zanussi 24 in. ZSF6160 Free-standing...
Zanussi DCE 5655 dish washer
Unplug at night if doesn't work change the L subport conversion chamber and remove the restricter plate
Feb 27, 2009 | Zanussi 21 in. DCE5655 Free-standing...
Water not heating
probably not, believe it or not. If they actually designed a trace to fail under load, then they could not predict when it may happen. Yes, things get more load-some over long use and demand more current, but the pcb trace was probably not intentionally too small. Let's say it was designed too small. So at first startup it carries 9.5 Amps. The next factory unit draws 9.8 amps. the next unit, wait a minute, draws 10 amps and blew the trace before it got shipped. I think this under-design was a simple oversight, but one that should have demanded a product recall from Zanussi that would send a tech to every unit to install a pcb with a beefier trace. Email Zanussi and complain! Just curious...can you measure how wide is this pcb trace? It should be about 1/4 inch wide.
Sep 19, 2007 | Zanussi 24 in. ZSF6160 Free-standing...
Zanussi Aquapulse DE6544 not emptying
Zanussi Aquapulse dishwasher - is filled with water inside, is not washing and the lights keep flashing on and off - has anyone any idea what may be wrong with it?
May 27, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Zanussi 24 in. ZSF6160 Free-standing Dishwasher Logo
368 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
